TBI 350 bracket below A/C compressor empty?
Woody Burban
CT
GMC Suburban V1500
I have a ‘89 Burban GMC V1500, TBI, below the A/C compressor, in the same aluminum bracket on the passenger side is an empty bracket pocket, it looks like it could fit an air compressor? Is there an air compressor I could mount in this void to power on bird air?
What goes here?
Woody
Goldie Driver
Houston, Texas
Britt
GMC K1500 Suburban
Probably for an air pump your rig is not equipped with.
I guess whatever will fit there is what you could mount.
Also wonder what Psi a factory air pump would supply ...
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
Khayward
North Idaho
Kevin
Suburban SLE
I know this post is a bit older, I just bought a truck that is also missing the smog pump, from what I can see there aren't any hoses or anything hanging loose, no obvious signs that it was there and removed. My suburban is a '90 originally bought in CA so this leaves me wondering if it was built this way?
80BrownK10
Greenwood, SC
Nate
In California, I would assume it had the smog pump. Look to see if there any pipe plugs in the exhaust manifold where lines would of connected or somewhere else in the system.
Khayward
North Idaho
Kevin
Suburban SLE
Haven't had a chance to dig around much, trying to get rid of the thrift store/ashtray aroma first but when I do I'll post photos of any plugged off stuff so other folks like myself know what it looks like
K10noob182
