Tank Selector Switch Dash Side Connector
Broken85
Cumberland, NJ
A
The dash connectors are the same. The only difference is the 87 switches have a nub on one of the prongs so they can’t be plugged into an 85ish harness, but you can grind that nub off with a grinder and they work the same.
CalSgt
CA
Casey
Chevy K-10 Custom Deluxe
I just used female spade connections on the back side of the ’87 switch. I much rather would have used a pig tail with the appropriate harness plug if I could have found one.
One thing to note is the switch didn’t fit in the hole for my 1980, I hade to grind the hole in the dash larger to get it in. It also doesn’t match the contour of the older dash perfectly but isn’t terribly noticeable.
wonone
