Talk me out of this...
79K15 HIghSierra
South Carolina
Reuben
K1500
Saw a NV3500 5 speed 4x4 trans come up on Facebook marketplace...for $250. Are these any good? It says it worked fine when taken out. Worth the trouble of swapping out my sm465?
Craig Nedrow
NADAR UNDER THE RADAR
Washington State
Craig
1973 (have two), 1985
K10, K20, C20
350, 454, 6.2 Detroit
Was it behind a GM, or Dodge, see below? they are longer, so both drive lines will have to be modified, around here very expensive. See below:
  • 1993[1] New Venture Gear releases the NV3500. Externally the earlier GM units look like the NV3500; however the internal components were extensively redesigned.
    • The HM290 and 5LM60 units have a complicated arrangement of 4 shift rails. The NV3500 has one shift rail.[2]
    • There are two designs for the 5LM60 input shaft and bearings (input shaft and main shaft). The first design 1988–1990 has a ball bearing with a roller bearing behind it. The second design has a much larger single ball bearing. The first design bearings are reputed to be failure prone.[3] The updated input shaft and bearings carried through to the NV3500.
  • All 5 of these transmissions can be interchanged as a complete unit with the following caveats.
    • "Drop-in" interchanges between GM S (S10 etc.) and C/K trucks will require modification of driveshaft length and crossmember placement. GM S models have a longer tail-shaft than C/K trucks.
    • Master & slave cylinder bore sizes went from standard to metric in 1992 (Master: 11/16"->18mm, Slave 13/16" ->20mm)
    • GM and Dodge transmissions will not interchange.
      • The case and bellhousing are one piece with differing, engine specific, bellhousing bolt patterns.
      • Dodge uses Dodge specific input shaft length, spline count, and pilot diameter.
      • Dodge output spline count differs from the GM units.
    • https://en.wikipedia.org/wiki/New_Venture_Gear_3500_transmission
Shorty81
Baby Boomer
North West ohio
Darren
Keep the sm465. Best truck transmission going.
Cemack
Alberta Canada
K15
I’ve got the Sm465 in my 78 gmc. Don’t like it much because of the throw between gears. It is a very good transmission though. I’ve also got an NV4500 in my 1998 gmc and like it about better. It’s just nice driving it. It must be a good transmission as well to have lasted so long too
rt66paul
California
paul
1991 suburban
alwaysbroken
