Tailgate security solution needed
WoodinVillain
Woodinville,WA
Kevin
1986 c10 needs a tailgate lock/security solution.
Notworried about tailgate theft. I need something to lock my tailgate with a key with tonneau closed. Of course i know nothing is truly theft proof, but rather a “deterrent” to casual walker by, just opening it freely.
I seem to remember Pop & Lock used to sell these for squares, but for some reason no longer do for square bodies . They start with 1988 +.
What are you guys doing to lock your tailgate with tonneau?
Whether it be a product or some slick custom solution..
(Fwiw, i have not bought the tonneau yet in case that is affected by the solution.
Currently have an old ultralight tall Gem Top. Great function… but not “summer fun” or sheckzy..
Thanks for any actual solution, especially with www. Link to a product. Or great pics/description of a custom solution or hack. Im totally open.
I have never seen one for these trucks, I'd definitely be curious to see if anyone has/knows of one. I will say generally, a normal soft tonneau has been enough to ward off idle hands for me so far and I've had my truck in some sketchy areas overnight. Thankfully with no issues
Install this in the tail gate like a door lock,attach 1 latch pull rod to it,so you have to turn it to pull one latch in,lift the handle for the other. Or use an electric pull solenoid with a reed switch or keyed electric switch,to oull 1 latch rod. It would make opening a 2 handed operation though. Another thought would be install this with a pull rod or wire going from this to the handle. When it's turned one way,it pulls at the handle in the opposite direction preventing a pull rod from pulling out the latch.
WFO
Texas Panhandle
If the tonneau has it's own lock, couldn't you use a barrel bolt lock on the inside of your tailgate?
saltdog
US
K20 Suburban
sorry-couldn't resist
Sad Sack
Nebraska
Goober
C15
WoodinVillain
Woodinville,WA
Kevin
The tonneaus ive seen that are available for mine dont seem to have a security option 5hat secures the tailgate. At least that ive found.
WoodinVillain
Woodinville,WA
Kevin
Getting closer! This has me thinking about a customizing a simple “dead-bolt” with key option if I dont find anything. Custom is often cooler.. but takes a lot of work even for simple mods.. though not quite this….
Really not much custom to make, 1 factory latch,1 premade lock cylinder,all you have to make is one pull rod. One factory latch would be your dead bolt. The lock cylinder I pictured in my previous post would be what pulled the dead bolt out of the pocket,really not much to it. Actually just disconnect 1 latch rod. Install key cylinder,run a pull wire from lock cylinder to latch. Use a cylinder like pictured,not a typical keyed cylinder. I'm afraid you would eventually twist a key off. If you park the cylinder in the right position it will be,twist the key 1 latch stays undone,lift the handle to open the tail gate. You could apply the sane pull wire lock cyl8nder principle to the tailgate pin someone else showed.
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
Put some kind of latch on the inside of the tailgate, lock that, then lock the topper/cover. Soft topper can't really do that.
Or do something on the inside of tailgate and then have a rod coming out the bottom of the bed like old school hood latches.
WoodinVillain
Woodinville,WA
Kevin
All great advice! It looks like a “custom” solution is doable, and not too tough. Was hoping for an easy “product” but maybe these are even better. Now you guys have me wanting to get more complicated (opposite my original goal) and figure a way to use a gm cylinder that can match my door/glove.. like what could have been a “factory” look.
Thanks guys. *side-eye* I thought I got away from never ending custom mods, when my Jeep was totaled.. (kidding..I love it, I just dont have enough spare time these days).
Now to snag a tailgate from a yard to test on next break I get. Because lets be honest, my first attempts will suck.. and this truck has 80k miles and is 100% uncut/modded survivor.. and I want to keep it that way as much as possible.
WoodinVillain
Woodinville,WA
Kevin
I think I’m this. Just need to figure it all out and figure a way to use a gm cylinder I can match to my door key (without risking twisting it off.. *hat tip to foresight)
dudleyrushmore
