mxer147
- Feb 8, 2023
- Colorado
- Jack
- k20
Since the knowledge is vast here and it’s been saving me time, thank you all, please inform me what the purpose of the switch under the headlight switch? Also, the gauge bezel doesn’t quite match up with the headlight switch and opening, a PO did a dash hack so not sure if the headlight switch isn’t located correctly? I usually do a search first but wasn’t sure what that switch is called and I don’t see it labeled. Windshield wiper switch is on the column and it’s not a manual choke pull. Also, what could be the purpose of the red indicator?
