Switches
mxer147
Colorado
Jack
k20
Since the knowledge is vast here and it’s been saving me time, thank you all, please inform me what the purpose of the switch under the headlight switch? Also, the gauge bezel doesn’t quite match up with the headlight switch and opening, a PO did a dash hack so not sure if the headlight switch isn’t located correctly? I usually do a search first but wasn’t sure what that switch is called and I don’t see it labeled. Windshield wiper switch is on the column and it’s not a manual choke pull. Also, what could be the purpose of the red indicator?
rusted nuts
Pa.
Jeffrey
k20
4cly diesel
What happens if You pull it???
squaredeal91
Cave junction Oregon
Greg bush
1991 SB
5.9 Cummins 12 valve
Looks like an add on. Probably not factory. Where do the wires go?
mxer147
Colorado
Jack
k20
It pulls out about 1/4”, three wires are connected to the back terminals, one goes to the red indicator, the other two go into the engine cavity. The two going through the firewall and into the engine cavity are heavily black taped and feed into the covered wire loom so not easily traced without unwrapping the tape. When I pull the switch nothing happens and no light indicator either. From the factory, did the wiper switch reside where the light switch is and the light switch was in the lower opening?
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
With a truck that old, and lots of previous owners and modifications, who knows what it was for? For all you know, whatever the switch controlled might be long gone.
If you really want to know, carefully trave each wire until you find what it’s connected to. The problem with that approach is the half assed “repairs” or modifications you will more than likely find.
I HATE fixing previous owners wiring. It usually turns into a major headache.
mxer147
Colorado
Jack
k20
Could this switch be a trans lock when this truck was an automatic rather than a manual as it is today? I’ve noticed a few threads with trans lock switch which looks similar.
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
There's something going on with the light switch. Looks like the bezel is mismatched too. What year is the truck? That's a late 70's bezel. Which switch actually makes the lights come on?
mxer147
Colorado
Jack
k20
1983 K20, upper switch is lights, lower unknown, the bezel is for windshield wiper on dash eventhough they are working at the column. The lower switch has three wires, two go through the firewall, one goes to the red illuminated near the switch.
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
Probably just a really hack way for some aftermarket lights or a bad headlight switch at some point.
82SquareBurb
