Swapping an 81 454 into a 74 pickup.
rumblebox
Victoria, TX
Carlton
Is there anything I should know regarding fitment before I do this? Is it as simple as it should be?
Sent from my LG-H910 using Tapatalk
Of course you're aware the exhaust will have to be changed. Fan shroud is likely to be different.
rumblebox
Victoria, TX
Carlton
Got those covered. Doing headers and E fans
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
The extra weight may also need to be considered. If your front springs are weak with the SB they are gonna be a lot weak with 300+Lbs more sitting on them.
rumblebox
Victoria, TX
Carlton
I should have clarified its going in place of another 454.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Oh then it should be a slam dunk. That was pertinent info.lol
Oh it's just a drop in swap them. Piece of Cake. You can do this one in your sleep.
rumblebox
Victoria, TX
Carlton
Just making sure there are no subtle differences between the year models.
gmachinz
Harnessworx Inc
Iowa
Jabin
The only thing I can think of is to correctly add the HEI 12V coil lead from the firewall bulkhead. 1974 is a one year only style bulkhead connector.
In 1974 there aren't any provisions for a 59-series male terminal-only 56-series. On your '81 GM used a larger terminal for both the coil feed and the main BAT bussbar feed off the firewall junction. I'd recommend upgrading the alternator tho to at least a 63-amp unit if not already equipped.
rumblebox
Victoria, TX
Carlton
I got the 6 trans bolts off, and it will not break loose from the block. Are there any im missing?
gmachinz
Harnessworx Inc
Iowa
Jabin
Did you unbolt the torque converter from the flex plate?
rumblebox
Victoria, TX
Carlton
It's a manual. It just needed a lot of persuasion since it hadn't been out in like 30 years
gmachinz
Harnessworx Inc
Iowa
Jabin
Ah...I didnt catch that part!
rumblebox
Victoria, TX
Carlton
Back to its former glory, and then some, soon enough.
rumblebox
Victoria, TX
Carlton
Nice rod cap...
alwaysbroken
