SUM-k1202 cam in ’84 c10
letgomyleghoe
Milwaukie, OR
shawn
350ci
Hi,
I’m planning out a build for my ’84 c10 with 350/th400 and a 12 bolt 3.08 posi rear end, I have 27 inch tires and will be installing aluminum 64cc heads to boost my compression up to about 9.5. This will be a weekend car for the most part, I have a van I use for work. Will this cam still be “street able” or should I look for something a little less hot, I would still like to able to drive this thing on 1-2 roadtrips every once in a while.
Cam is 4/7 swap
218/228 duration
109lsa
.465/.473 lift with 1.5 rockers
xm20k
Girard, Ohio
Thats practically stock compared to the one I drive daily in the summer. You'll still have vacuum brakes too.
11.25 compression
252/252
110
.600/.600
4000 stall
457 gears on a spool
32 inch drag radial
letgomyleghoe
Milwaukie, OR
shawn
350ci
11.25 compression
252/252
110
.600/.600
4000 stall
32 inch drag radial
Yeah I’m hoping to keep it right in the middle, not hot but not mild. I’m open to swapping to a higher stall converter, I just want to keep the 3.08 posi rear end as a majority of my driving style is backroads and highways >60mph. I’m thinking I’m gonna go 1.6 ratio rockers which will put it at .504 lift intake side. Do you think I’ll need a higher stall converter with 1.6 rockers? Or should I send it and expect to possibly be swapping the converter.
xm20k
Girard, Ohio
That duration shouldn't be ratty enough to need a converter, it'll idle with a bit of a lope, have vacuum for power brakes. Decent upgrade from the stock cam for daily use I'd run it with your planned build.
letgomyleghoe
Milwaukie, OR
shawn
350ci
Sweet thanks for the input!
dudleyrushmore
