Suburban head liners
NoMas
Cocoa
Suburban 1500
I've been looking at headliners where everyone getting there's ? I do interiors so might just stitch one up, there all over 700 that I've found.
YakkoWarner
Central Texas
Wolf
R2500 Suburban
I removed the falling and largely decaying fabric from mine - the composite board material was undamaged just the fabric and adhesive was dead. If I could figure out how to remove the composite board without damage I'd just sand it down and paint it with a similar-to-interior color and not bother with fabric again at all.
NoMas
Cocoa
Suburban 1500
I don't have anything up there, wasn't sure if it was a board or hung material on rods like some cars. Guess I need to do some more research.
Moderator
The headliner material is a foam-backed cloth. The foam backing is what fails. All the decomposed foam remains need to be lightly BRUSHED off of the headliner board so there is a good foundation to glue on the fabric of your choice. GM used two different types of headliner board material and while one puts up with a little more abuse, neither one takes kindly to sanding. Cleaning with a stiff-bristled nylon brush is a safe way to go to remove the old foam remnants.
YakkoWarner
Central Texas
Wolf
R2500 Suburban
I used a shop-vac and brush to get most of the loose foam off so i wouldn't be breathing the stuff. Good to know about not sanding. Going to be a while before I even consider it since the whole truck is dead again at the moment anyway.
WFO
Texas Panhandle
I wonder if, after brushing off the headliner board, a coat of spray paint on the board would help adhesion even more.
Moderator
I don't think so. I believe that would actually hinder adhesion.
One thing I have read can be done and I do believe would help (especially on a headliner board that is getting a bit loose and floppy) is to apply a coat of fiberglass resin. Although you'll have to make sure the board is well supported and properly contoured as the resin hardens. Suburban headliner boards are also prone to sagging and actually reforming like that. A good heavy layer of resin might actually soften it so it can be reshaped and then of course, possibly cure while holding the correct shape.
awar
K35
I had my 84 Suburban headliner redone when I purchased it in 1998. The upholstery shop removed the droopy cloth and the foam and installed new fabric/foam. We also installed a couple Crown Victoria dome/reading lights at the same time. I traded work with the upholstery shop so I never got a price. It was better than new when done.
Goldie Driver
Houston, Texas
Britt
GMC K1500 Suburban
Some info here for you :
I went with the Classic Headliner material - not perfect, but close. The trim shop had to do some repair work on the backer but it turned out well and does not sag , which was the original issue.
I do miss the snakebite pattern, though ... ;)
NoMas
Cocoa
Suburban 1500
Thanks everyone, mine came with everything removed, didn't get a board or anything. And wasn't sure what went up there, so guess I'm hunting parts. It's been sitting in a building for over 20 years, rust free nice truck. Motors out but good. Maybe all have some luck finding a used board if they last, I'm familiar with headliners and cleaning off the old foam. With a quick glance I thought it might have been the older style bow rod type, I didn't at all think it had a glued to board style.
awar
K35
Car-part.com is a listing online for commercial wrecking yards advertising available parts. You can search by your Zip code to see who has what in their yards. You might be able to find a donor rig for the trim and the backing boards. They are two piece, front and back if I remember correctly. I got rid of my Burb in 2005. My crew cab does not have a headliner of any kind. It was a custom deluxe when new.
HotWheelsBurban
Houston, Texas
Carol
R2500 Suburban
What we ended up doing on our 79 and 84 square body Burbs, was getting some thin rolled automotive carpet (iirc from Walmart auto department, about 25 years ago) and gluing it to the boards. We got extra top bows at the yards and installed them, to cover up the seams; the carpet was only about 24-30" wide. We used 3M spray trim adhesive, the professional grade. Held up well in the Texas heat.....
Judge
