Steering shaft woes
Ohearchai
Washington
Martin
V1500 Suburban
1990 suburban v1500, had a leak at the input shaft seal, was gonna replace it, before buying a new box. Took out the necessary bolt, shaft is seized, cannot get it back far enuff to clear the spindle. Options cut rhe shaft, replace the shaft, replace seal, and see how it is. Or just go the whole way, get a new sterring box as well.
legopnuematic
Licensed Junk Dealer
MO
Spencer
The steering shaft has plastic injected in it to hold its dimension, then in the event of an accident it can slip and collapse, to not impale the driver. If it hasn’t been collapsed before it shouldn’t really move.
Loosen the steering column, two bolts under the dash, two on a clamp where it emerges from the firewall and pull toward the rear of the cab, should give a 1/4”-1/2” of movement. If you need more, remove the nuts on the under dash mount and drop it off the studs and pull further.
dd1990
Oxnard, CA
Suburban 1500
I used a long crow bar to un-seize my steering shaft, I had alot of slop went with a new box and c3500 steering shaft
nvrenuf
Mobile, Al.
If you have a friend with a torch, heat the shaft in the middle and the plastic will ooze out freeing up the slip joint.
I was going to say pretty much what legopnuematic said. Unbolt the column from the cab. NBD .
Chevy 88
Canada
f7t6
GMC
Probably doesn't matter now, rather than moving the shaft away from the box, couldn't you move the box away from the shaft?
Unbolt it and move it forward / down?
Sounds crazy I know - because normally us guys are always trying to move the shaft closer to the box.......
Ohearchai
Washington
Martin
V1500 Suburban
Okay I will give this a go, remove these 2 bolts, pull back and hoping that gives me e off clearance. Thanks to all.
Marty.
Trucksareforwork
Spartanburg SC
Geoff
You’ll have to unbolt it under the dash as well. Two large bolts.
I heated mine and melted the plastic. That allows it to telescope.
Ohearchai
Washington
Martin
V1500 Suburban
Have four, these are 2 others,
legopnuematic
MO
Spencer
Ohearchai
Washington
Martin
V1500 Suburban
Cheers for that, got her done, although I should be probably go the whole hog and throw a steering box into her
wonone
