steering column question at tilt joint
garettjaxx
Washington
Joe
V6
I was wondering what the cause is for my tilt steering wheel to be completely loose at the joint where it tilts. I can take the wheel in my hands and move it up and down quite a ways. The column itself isn't loose.
thx
1983 k10 350 700R4
buRRp
Grand Forks ND
Lee
V2500 Suburban
I had that happen on my 91 burb. It was real bad. I just replaced the column with a used one from the salvage yard.
davbell22602
Bunker Hill, WV
I Dont
Have
One
There's a special tool for removing the pivot pins if the squares had them but some will just drill them out and replace.
What tool is it?
oneluckypops
Sedalia, Mo.
Luke
K30 SRW
What tool is it?
I wouldnt advise "drilling it" as I recall the pins are pretty hard and if you get off center you ruined your columb
davbell22602
Bunker Hill, WV
I Dont
Have
One
Thats it matco has it for $20 bucks.
oneluckypops
Sedalia, Mo.
Luke
K30 SRW
that one I have pictured is less then $8.00, that what I have TRIED to tell you NOT to be BUYING the snap on and matco tools, it is a waste of money.
I'd like to see it in action. I never had a column apart down to that point.
davbell22602
Bunker Hill, WV
I Dont
Have
One
I understand what your saying but going the cheapo route isnt always good in the long run on anything including auto part buying because sometimes you spend more replacing it everytime it breaks verse buying the that costs more that may never break from real tool company.
oneluckypops
Sedalia, Mo.
Luke
K30 SRW
lol to my knoledge MATCO does NOT make ANY of there OWN tools, ONLY thing you are doing is paying for a name. The tool your looking at will more then likely only get used a few times in god only know how many years, The columb is not produced anymore.
I'm fairly certain that you don't need to pull those pins to do it. At least not to tighten the top two bolts, which will usually take care of the problem.
oneluckypops
Sedalia, Mo.
Luke
K30 SRW
you may be right, but I have always just pulled the pins. I actually am needing to do this to the K30, when I do it I will take some pictures along the way and do a write up so we have our own on the forum.
kleedus
wyo
Ray
1960 threw 91
c10 to k30
350 threw 454
i made my own tool for pulling those pins
i always pull all 4 out and loctite them back in.
its not that hard once you figure it out its kind of easy
Hard
