Stalling under take off
Mango
JacksonWyoming
Gil
Did not run out of fuel it was very very low gauge was reading 1/8
Very,very low tbi will act up,just because it's too low,especially at stops,hills,turns or takeoffs. Is it still acting up.?
Mango
JacksonWyoming
Gil
Was running great filled up drove about 25 miles hyw speed and in town stop and go, On my way home from work the second stop sign it stumbled on take off next stop stumbled again did not stall Drove into subdivision 15 MPH and it stalled twice started right back up Back on roar at 35 MPH stalled put in N and fiired back made it home ??
Mango
JacksonWyoming
Gil
No Backfired Checked all vac lines OK Looked at plug wires OK Looked at spray pattern hard to see lots of fuel going in at cold start Idles perfect?
Mango
JacksonWyoming
Gil
Problem Solved
Replaced the ICM, while i was in there also replaced the Rotor, When reconnecting the coil wire to the ICM first one no problem second one the Flipping tab snapped off and went flying??
Luck have it be NAPA had two in stock
Test Drive no stalling yet only time will Tell
The other thing that happened Odometer rolled over to 200,000 Miles :oops:
squaredeal91
Cave junction Oregon
Greg bush
1991 SB
5.9 Cummins 12 valve
Problem Solved
Glad you got it resolved
duncan_schawalder
