Square body brake upgrade
btfelker
NC
Bobby
1500 suburban
I love my classic Suburban but the newer autos brake systems have spoiled me. After some research I installed an OBS master cylinder and 3/4 ton rear wheel cylinders. Massive differance. However, with the master cylinder tank was to tall and hit the hood. More research lead to swaping out the tank with a 2000 S10 reservoir. Everything was a direct fit and easy upgrade for my 4,450 lb burb.
Look up the possible consequences before performing this modification. The GMT 400 uses a quick take up master cylinder designed for use with low drag calipers. Squares use conventional calipers.
Shifted
