springs not straight with each other?
adamv7010
nc
adam
k10 silverado, k10 suburban
i noticed tonight that my front 4" RC lift springs in the front are not flush with each other while looking straight down them. like theyre sort of 'spun' on the center bolt...
is this normal??
i have no clue whatsoever...i've never seen it happen before at least
There should be clamps that keep the individual leaves in place.
Really though, even if those clamps are gone, the leaves should stay in place for the most part... IF your u-bolts are properly torqued. In other words, make sure your u-bolts have not loosened up.
smurph20
Clyde, Arkansas 72717
Brad
350/SM465/NP208/4.10's
My S10 did that before i put the lowering kit on it and then after i lowered it i redid the torque on the ubolts a week after i did it i never had another problem with it.
adamv7010
nc
adam
what are the torque specs for the u bolts?
the lift was on the truck when i bought it and i cant find it on the rc website
It's a broad range, like 110-140lbs I think.
adamv7010
nc
adam
thanks guys...i believe my wrench is upto 200...so i'll just get it there...should be good
It's 150-170 for the 5/8" fine thread....
Yeah, that sounds more like it. The 110-140 must have been the S10 u-bolts I did last... I hope. Hehe, maybe I should go check my u-bolts.
smurph20
Brad
**** i just hammored on there with my snappy 1/2 impact gun till i figured they were tight lol
dirtroadoutlaw
Florence, MS
k5
That's how you end up with broken tie bolts & wrung-off perches & all those lovely things: incorrect/insufficient torque on your u-bolts.
Tyger13us
BFE,Ut
Jeff
450hp/357cid
I wouldnt go over 110 pounds,, it trys to break off the sway bar support pad ears much more than that for that year of truck/sub....
Tyger13us
BFE,Ut
Jeff
450hp/357cid
joseph916
