spring perch lift
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
Curt
K-10
350/SM465/NP205
OK so that means the end of the spring is 8" above the bracket. When it is flipped it will be 8" below the bracket for a total of 16" of difference but since it is only lifting the rear half of the spring it will only net around 8" lift. And that seems like too much. Most of the time I've seen 4" shackles, flipped equaling 4" of lift. With 8" of shackle flip lift your pinion angle is really gonna suck which is why I'm saying I dont think it is actually an 8" shackle. Not calling you a liar just saying get a ruler or tape measure and be sure. Cause if it is 8" you're going to have some work making it work right. How much lift are you wanting to get anyway?
chevydude
arizona
hunt
k20
Ok so I just did a accurate measure it is 6 inches so i should get 6 inches of lift out it if I understand your last post correctly.
I dont think so, more like 3.5" but since I dont have a stock one anymore I can't say for sure. I can say the ORD shackles look longer than stock and yield 4" of lift flipped.
I know it's longer than 3.5, I thought it was 5-5.5 inches. Maybe it's only 4.5 inches long. Also, I think the ORD brackets might move the pivot point up slightly, compared to the stock hanger.
crazy4offroad
Curt
K-10
350/SM465/NP205
Ok i see what ure saying it is 7 inches I will get about 3.5 inch of lift.
LOL no. If the shackle is 7" long, and you move it 7" below the frame rail by flipping it, that's 14" which has to be divided by 2 so it will net around 7" of lift. I would like to see a pic of that shackle.
chevydude
arizona
hunt
k20
No i posted the one you quoted then removed it i understand since it is 6 inches then the diffrence is 12 divide that by 2 an you get 6 inches of lift am i correct.
crazy4offroad
Curt
K-10
350/SM465/NP205
Yep you got it now. You still may run into pinion angle problems but nothing that cant be overcome.
chevydude
arizona
hunt
k20
Yah i thought i would have to use angled pieces to move it to help the angle.
Cool thanks for all the hep guys.
GreaseDog
Elkhart, IN
1977 K20
1980 K2500
Stock rear shackles are 4" center to center.
chevydude
arizona
hunt
k20
The shackles are off a chevy 1 ton crewcab and i measured and from bolt to bolt they are 6 inches.
:popcorn:
kleedus
wyo
Ray
1960 threw 91
c10 to k30
350 threw 454
i temp done it on my mud truck just to get the back to match the front
12'' front springs
stock blazer rear springs 6'' block and the home grown shackle flip
i do not like it i would never run it like that
shacle flip gave that truck right around 4''
i have taken 2 wheel drive truck hangers off the front of the rear springs and used them and liked it that way
chevydude
arizona
hunt
k20
i have taken 2 wheel drive truck hangers off the front of the rear springs and used them and liked it that way[/QUOTE]
Can you explain what you mean. Did you take the hangers of a two wheel drive truck.
elstm3
montana
lynn
V30 crew cab dually
6.2 twin turbo diesel
Take the front rear leaf spring hangers from another truck and use them for the shackle flip in the rear.
kleedus
wyo
Ray
1960 threw 91
c10 to k30
350 threw 454
the 2 wheel drive chevy trucks have a sorter front hanger bracket then the 4x4
i have used them for a rear shackle flip
i the picture this guy did it with a 4x4 front spring hangar but i liked the 2 wheel drive one
Villano
