Speedometer refuses to work. Any help is appreciated
projectmidnight74
Mississippi
Eddie
V8
So at this point, the original th350 has been rebuilt, I have put a new speedo cable in as well as a speedo bullet because it was leaking. I still have 0 mph when driving. Any help is appreciated otherwise, Im just going digital everything soon lol.
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
Either something wrong with the mechanism in the gauge or the input is slopped out on the gauge. Did you look at the drive gear on the transmission output?
projectmidnight74
Mississippi
Eddie
V8
Yes. It looked to be fine. But again I'm a novice at this lol. I have a yellow one I bought new. But didn't out it in. May have to just got digital.
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
Have you checked if the cable spin at the gauge end?
You should be able use a drill to spin the transmission end, and it will make the speedometer read. If that works, then it’s the transmission connection you need to work on.
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
Its brand new. No way its bad right. I guess I need to check.
Even if brand new, doesn't mean it's good. But it also means you could have not got everything together just right.
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
Is the drive gear in the output shaft?
Raise and properly support the rear of the truck so the termites are free to turn. Disconnect the speedo cable, put the shifter on neutral. Spin the driveshaft by had, make sure the driven speedo gear turns.
If not, you need to figure out why.
There are different speedo housings depending on gear. As the speedo gear count goes up, the gear gets bigger, the housing has the hole offset to accommodate the larger diameter.
Rusty Nail
Rusty
350sbc
That's all the good help I had ...chuck it in a drill. :rockit:bet that mother humper gon spin now aint it??
Dontcha know!
projectmidnight74
Mississippi
Eddie
V8
all I have are impact drills lol. any plan b to turn this sum gunn lol. Recap.
New speedo cable
new bullet
same gear with a new yellow one on standby.
Don Ainsworth
Gulfport, MS
Don
Under the hood locate the speedo cable and push it into the cab. You may just get lucky.
borrelemily7
Marksville, Louisiana
Emily
C10 custom deluxe
250ci
inside the transmission is the speedometer gear drive. it is a plastic pieces with teeth. different transmissions call for different number of teeth. it is pretty simple to remove. check it. mine was a mechanic shop and while there it disappeared??????? I am just having trouble finding the correct number of teeth that my 78 C10 requires.
projectmidnight74
Mississippi
Eddie
V8
A followup.
After intalling my 3rd speed bullet because of leaks, I figured I would ask the parts guy for help. The gear is brand new. When removing the bullet this time, I spun the cable end and guess what, IT FRICKIN WORKED, but, when installed with the new bullet, same results. I was told to point my camera in the hole and look for a spiral gear around the shaft. I am attaching pics, I didn't see the gear that I think is supposed to be there and I believe that is my problem. Any help would be great.
projectmidnight74
Mississippi
Eddie
V8
Pics
sallyjeank10
