Speedometer Qustion
1sic4x4
Az
Stan
k20
350ci
:boti:I have a speedometer that isn't working, took dash apart cleaned things up and check if Speedo moved when attached with drill, it did, ?, the cruise don't work can I just buy a cable for non-cruise truck and install from trans to speedometer and by-pass cruise? Is this a square brain bowtie Idea?:boti:
towjoe
Lafayette,IN
joe
78,80,81,81,86,88,89
K30's or V3500's
yea you should be able to bypass cruise with just one cable. did you ever think cruise didnt work because cable from trans to it was bad? could also be plastic gear in transmission stripped
1sic4x4
Az
Stan
k20
350ci
This is my first Square Box, and I don't know much about electronics or cruise but I am willing to learn. I spent a lot of time trying to find a resource to help figure out that it had cruise. If I were pointed in the right direction maybe I could get that working too! THANX I do appreciate all help
alwaysbroken
