Speedo quit working.
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
That’s a cable driven speedo. Unscrew the cable, make sure the plastic gear inside turns when spinning the driveshaft. If not, most likely one of the gears has stripped. If it has stripped, don’t replace it until you have inspected the cable. If it’s tight and hard to turn, either lube it or replace it. The gears are different colors, with different tooth counts to calibrate the speedo.
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
That last part I did understand, with the color coordinated drive and driven gears to calibrate the speedo based on tire size and gear ratio.
Maybe today, assuming it won't be raining, and after I mow the damn grass (lol @bucket ), I'll take a look at it, see what's going on.
Do you have a recommendation for who to buy the driven and driven gears from @Matt69olds
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
I know most speedo gears are available from TCI. Visit all your local transmission shops, Whatever It Takes (WIT) transmission, hopefully one of my suggestions works out for you
By chance, do you happen to see one of these behind your speedometer?
Vbb199
Salisbury NC
Vince
Honestly can't remeber, I'll let you know when I pull the clustwr, why?
That's just a regular ol speedo cable, with a drive and driven gear in the tailhousing. The VSS mounts to the back of the cluster and has an optical sensor of sorts that reads off of the speedo. Most 80's GM vehicles used the same setup, before electric speedos were phased in.
sounds like a simple speedometer cable setup but with more steps
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
Until electrical speed sensors were used across the entire production line, it was cheaper to add a speed sensor to the existing speedo head. Once speed sensors and electronic cruise control become common was it cost effective to change everything.
Unless it benefits the bean counters, nothing changes unless absolutely necessary!
Vbb199
Salisbury NC
Vince
Found my issue.
Broken half piece cable.
also learned evidently this 89 has a 2 piece speedo cable.
I have a 4x4 cable, should work tho?
Goldie Driver
Houston, Texas
Britt
GMC K1500 Suburban
Found my issue.
Dunno for sure, but if ya got it, try it. As long as it screws in I can't see you doing any harm.
Vbb199
Salisbury NC
Vince
Tried a 4x4 suburban speedo first, no issues, but the sheathing had cracks, so it was binding the speedo... Causing it to jump up and down when accelerating.
Took the speedo cable off the k5, which had no damage, speedo works great now!
Locks up in 4th as well
Misty Blue
