speedo driven gear in transfer case same as T400 driven gear?
ronniebomb
n.e. Ill
ron
K25 Sierra Classic
454/t400/np203
Hey Y'all!
I'm pretty well versed in the automoblile rear wheel drive world as far as figuring out what driven gear I need and where to find it.
But, I need to know if the gear in my 203 transfer case is the same as a standard T400 driven gear?
1978 GMC K25 454/T400 203 3.73 gears
So, assuming I have the 15 tooth drive gear (that would be in a T400 output shaft) I'd need a 34 tooth driven gear because I have 33's on now.
Is this correct?.....or is there a different style of gears in the transfer case???????
I already ordered the 34 tooth T400 gear...........so I'm hoping I assumed correctly!.,...lol!
Thanks ahead of time!
ronniebomb
n.e. Ill
ron
K25 Sierra Classic
454/t400/np203
Upon further research, it looks like the system is different...........so..........
Can anyone help me locate information on the np203 transfer case speedometer gear system?
I see some different spline count plastic gears on ebay, so I'm guessing that the output shaft has the drive gear cut on it?......
So I would need to know what that spline count is......
Then I could figure out what plastic gear I would need..........
Help please!
Craig 85
Nashville, TN
454/TH-400/NP205
Several of my squares with 203's ran an adapter similar to the one below. There are several companies that offer them.
idahovette
Weiser Idaho
Perry
K20-K10
The driven gear in my 203 is a metal gear 31 tooth I believe and there are a few others, at least a 30 tooth and a 32 tooth. I am looking for a 32 tooth now.
ronniebomb
n.e. Ill
ron
K25 Sierra Classic
454/t400/np203
This is probably the way I'll have to go, I happened to have one that's a 1:1.300 ratio that I installed Friday. It over compensated....... I was 4 mph slow @30, with the 1.300 I'm 5 mph fast now.
So I'm looking for a 1:1.160 adaptor. I have an email to speedometercablesUSA out of Denver. I hope they can hook me up with what I need.
idahovette.......this seems to verify that there aren't too many choices for driven gears on the 203's.
mmerlinn
Here, there, and everywhere
mmerlinn
1977, 1993, & 1993
Ranger, Aerostar, & Aerostar
460, 181, & 181
Hey Y'all!
NP203 driven speedo gears are all steel on an integral steel shaft.
List of known gears here >>>
https://mmerlinn.com/catalog/lil_wane111/xn_203/xn2034m0.htm#d
imyourhuckberry
