Spark plug mystery
2manyburbans
Florida
Drew
K10 suburban silverado
5.7 v8
the truck had been running good for the last 4 months until it got colder out then it was constant hard starts last night the fuel pump acted as if it was weak I tapped it with a screwdriver started working just fine but as I drove the truck fell flat on its face miss firing and backfiring through carb like crazy im at a lost this spark plug is from the front driver side im gonna pull more and see if I can start there any help would be more than appreciated love you guys
2manyburbans
Florida
Drew
5.7 v8
passenger side very front
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
Backfiring is a lean condition. The plugs also look a little lean.
You had to tap on the pump to make it come alive....
The pump is dying, and running the motor lean.
Replace the pump, maybe the filter too
Vbb199
Salisbury NC
Vince
Side note we have the same color suburban.
Mines an 89. I assume yours is too.
Do you by chance have any spare body panels ?
2manyburbans
Florida
Drew
5.7 v8
After taping the pump yesterday the pump works like it should it fills up the filter "not very quickly" but it does and the truck sounds like it running rough and shaking pretty bad instead of a smooth rev it's like it bubbling kind of sound and my burb is a 85 and what panels are you looking for
Vbb199
Salisbury NC
Vince
Im looking for a drivers front fender, same color as your truck
Tapping on a mechanical fuel pump won't do anything.
Are you saying it doesn't always fill the fuel filter?
Vbb199
Salisbury NC
Vince
Is this some aftermarket electric fuel pump?
Or the mechanical pump on the side of the motor?
Craig Nedrow
NADAR UNDER THE RADAR
Washington State
1973 (have two), 1985
K10, K20, C20
350, 454, 6.2 Detroit
Bottom pic is a hotter plug, and the burn pattern shows it. I have burnt a hole in two different engines because of a lean condition, just saying. Every electric pump i've had would fill a holly carb, both bowls in seconds.
3 Ton
Pacific Northwet
Fred
1978-79 78 body, 79 gearing
K-15 Suburban
You can measure the fuel pump pressure. In a rare instance the valve can pop loose and plug the outlet.
ALL fuel pumps are chinese made and very bad for older rigs. Have your OEM on rebuilt, or do it yourself. Kits are out there.
and not chinese ones. Now & Then in Maine is your connection for fuel pump parts.
Backfiring IS a lean condition.
I missed where you said what type carb it is. So cant help ya there.
Again with the China thing...
Not all fuel pumps are made in China.
bigrich
