Sound Deadening yes or no??
aGood'olBoy
Waterford Pennsylvania
Jeremiah
With the money from my tax return i was planning on installing a complete system in my truck. One of my Christmas presents was enough bed liner for my bed and inside of my cab. I have no carpets and only some autozone floor mats. So i was going to do the inside of my cab with the bed liner. I'm worried that because its a single cab truck with no insultaion that sound quality will be sacrificed. The only route for sound deadening i can go (as far as i know) is spraying on lizard skin. That stuff is kinda pricey but i can put the bed liner on top of it. So I'm wondering is it even worth it? Any opinions and input is appreciated.
Irishman999
Safford Arizona
Jason
K-1500 High Sierra
I hear alot about lizard skin but have never tried it. I am a fan of Dyna mat, that stuff is the ****. Just cut it to shape with a razor knife, peel and stick where you want it. I did doors only in my 85 and it cut WAY down on noise in the cab, I highly recommend that stuff.
Konas new ride
Alberta
Gerald
I would paint what i want looking nice and use Dyna mat like Irishman said. Works fantastic. With Dyna mat you don't need to cover the whole panel to get rid of sounds from a panel.
Irishman999
Safford Arizona
Jason
K-1500 High Sierra
But could I still paint the bed liner on the dynamat?
I wouldn't. Bed liner is a pain in the ass. Just put down some rubber floor mat
Sent from my ADR8995 using Tapatalk 2
aGood'olBoy
Jeremiah
I have some cheap floor mats. But I'm going to get the inside of my truck full of mud water snow you name it. So for nays real aren't going to cut it to be frank. I don't want to shell out for a big polywhatchamacallot piece that goes across the whole cab.
Could I just use the dynamat in the areas of the speakers and in the doors?
MrMarty51
Eastern Montana
Martin
The "TRUCK" rubber floor matting works real good. Keeps the moisture from penetrating and is easy to clean, use a garden hose.
Pull up the sill plates when done warshing and let the moisture dry out, put the sill plates back down.
Lasts for many years too.
That is all we had in the snow plow trucks that the Montana D.O.T run and never had any rusted out floor boards.
Less than $120.00 from Rock Auto.
Konas new ride
Alberta
Gerald
Yes Dynamat inside the doors..
Rockstargraphics
Oshawa, Ontario
1500 Wrangler
5.7L
I wouldn't use Dyna Mat, Look up Fatmat and Shok Industries Sound Mat. Same thing as dyna mat and cheaper. I build full audio builds and chose not to use Dyna Mat rather go to a small company that makes the same ****. Look up a retailer in your area for both products. You can spray your bed liner first and then put the mat down after I do it all the time. It helps with sound quality I know the old guys will say use Dyna Mat but trust me you can get a full car package for a great price and have extra.
Irishman999
Safford Arizona
Jason
K-1500 High Sierra
Im gonna give fatmat a try on my 1990.
chevyk10
WV
Daniel
1984 chevy
k-10
358 Dart block with aluminum heads 430hp/450ft-lb torque
I got the jegs brand it it seems pretty nice.
chevyk10
WV
Daniel
1984 chevy
k-10
That's a good deal if it's thick enough. Not sure what mine was.
John81287
Mchenry,IL
V20
Thickness:
0.050" (1.1430mm)
Mass:
0.42lb./ft2
Temperature Range (Optimal performance):
14°F to+140°F (-10°C to +60°C)
Temperature Range (Resistance):
-50°F to +300°F
Chemical Resistance:
Resistant to water and mineral oils
48.7lbs/inch on cold steel
Reflective Aluminum Layer:
4mil thick
PSA(Pressure Sensitive Adhesive):
1 mil thick
Handling and Application:
Store at room temperature for best results
ASTM E756 @ 200 Hz:
0C (32F)
0.20
10C (50F)
0.23
20C (68F)
0.35
30C (86F)
0.27
40C (104F)
.020
Works Great For
Nasty Rattles & Vibration
Blocking Loud Exhausts Noise
Stop Road Noise & Quiet Your Ride
Improve your SQ & SPL
Great For Heat Reduction
(GET MORE BASS)
Restoring Older Vehicles
Isolating Sound & Engine Noise
What's Included In Your FatPak
100 Sq Ft of FatMat eXtreme
Free FatMat Roller For Easy Installation
Free FatMat Handy Cutting Knife
FatMat Decal
Installation Instructions
12turnda
