Somebody tried to steal my truck.
Kills switches help, and so do gas shut off valves but not much you can do for someone driving around with a self loader stinger towing them off. Usually the pros using that kind of equipment though are looking for late model trucks and SUV's like Escalades and Denalis.
towman
harrisburg pa
jay
v10
to protect from the theives with tow trucks, park it where it would be a nightmare to get to, close to poles the steering wheel turned ect, with running a tow truck it is easy for me to pick places to park
Manbearpig
Midland, Tx
Tyler
1500HD Quadrasteer
**** that's terrible
And if possible, back into walls or your driveway, and put your park brake on. This way if he does hook up and tries to drag it off, the skidding rear tires will slow him down and likley make some noise to alert someone. Ideally, they'd like to hook it in the rear and get the drive wheels off the ground and why towman suggests turning the front wheels. Going down the road mega sideways is sure to attract some attention too, and if in a narrow residential street chances are they won't make it down that street if cars are parked on both of the street, without hitting something.
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
Curt
K-10
350/SM465/NP205
I used to repo and we could get around those tricks, and didn't mind towing someone's car way sideways lol. Main thing about cutting the wheels close to a pole or wall is if they try to tow it the turned wheels will direct it into the pole or wall, which is something we didn't want, to damage the vehicle. But we would have a chain set up so all we had to do was pull up, hook up the chain and pull it real quick away from the obstacle, then hook up for tow. We would also go ahead and hook up to whatever end we could get at and I would crawl under and quickly pop the shift linkage loose and pop the trans in neutral. You can't stop someone if they really want it.
NO doubt if they want it they'll get it. All you can do is make it harder to get. Hopefully you've made it hard enough, they might just decide to move onto an easier target. Its also easier to repo a vehicle than it is steal one, knowing you don't have a risk of going to jail for a repo.
Irishman999
Safford Arizona
Jason
K-1500 High Sierra
I guess the best thing to get is Lo-jack or some other tracking device.
jguerra2
