77 K20
- Nov 9, 2012
- Montana
- Mike
- K20 5" lift
- HT383 fuel injected
I have a 63 amp alternator in my truck right now, and it is only a year old. Works great going down the road, but at idle- not so much.
Last night it was raining so I have the wipers on and I'm sitting at a stoplight with the headlights on. Everything is getting dim, volt gauge shows 11 volts or so. I power brake it a bit just to raise the RPM by 100-200, and the lights get bright again, and volt gauge shows 13-14 volts.
I've seen write ups on larger alternators, but all I need is more amperage at a low RPM (idle).
Putting a slightly smaller pulley on it would do this- make the alternator spin just a bit faster.
Has anyone done this and know of any part numbers? Am I overlooking anything here?
