Sliding Window
Kurtofvdg01
Kurt
I took my doors off my blazer to make some custom panels. Since the doors are off, I thought it would be a good time to restore some of the weather striping throughout all the door and all the electrical components. How can I get to the window power motor and all the rubber that goes on the inside of the door?
theblindchicken
SoCal
Christian
K10 5" lift + 2" BL
350-4, 0.030" over
Not sure what rubber you mean, but should be able to access the motor and regulator by removing the arm rest, pocket, and the door panel. Then probably have to loosen everything up to pull it out.
CRM
Pasco, Washington
Casey
K2500
350 CI
You might check youtube. A lot of good videos on their website.
mick84
