Skipping when in OD
radio2000
South Carolina
83 and 88
83 C10 and 88 R10 Burb
'88 R10 Scottsdale Suburban (TBI) has a pretty noticeable skip when in overdrive and engine under load ie going up a grade. If I give it a lil gas so it will down shift, no skipping. Any ideas?
4WDKC
Southern Florida
Kacy
Skip like a lean buck or snort?
radio2000
South Carolina
83 and 88
Haha
Not sure what those are, but it's just a really sorry hesitation
yevgenievich
Place
Name
Year
Model
Size
Likely either ignition or lockup clutch
The torque converter clutch in my Caprice was doing this. Get it out of fourth, and it got much better. It could cruise along okay, but increase the load, increase the shuddering, bucking, and chattering. I put three bottles of Dr. Tranny Instant Shudder Fixx in there, and it pretty much fixed the problem.
gpmorgan
Tupelo Ms.
greg
I would look at the distributor cap and rotor. These are known for moisture getting in them. Had the same issue with mine. Only did it in od.
radio2000
South Carolina
83 and 88
Thanks everyone
Cap and rotor seems like the easiest to check. I'll try that first, then clutch.
4WDKC
Southern Florida
Kacy
My truck was cutting out causing it to stumble and spit only while in OD, fixed an exhaust leak at the block/manifold and it stopped doing it.
FenderBanger
