Silly Question about gas pedal
1986ChrisK10
Mississippi
So maybe I have been super spoiled with drive by wire these past 17 years. But is there a way to lube the gas pedal cable? It seems to take a good effort to push the gas pedal.
I finally got the truck on the road and stretched its legs. After driving it a good decent distance now, it seems my idle is super low. But it ran great before with just yard driving. Any ideas on that?
Jrgunn5150
Questionable methods
Ionia Mi
J.R.
6.slow
Yes, you can lube it with lithium or graphite. You also may want to look at your throttle return spring, it might be too stiff.
1986ChrisK10
Mississippi
Thanks Jrgunn, I was away and unable to respond on my phone.
johnnydefacto
California
C30 Dually 3+3
I have a TBI 89 so it may not be applicable, but i also had a really stiff pedal, especially the first inch or two. I did what everyone told me to do and lube it and then replace it. Lubing it didn't work, so I replaced it with aftermarket from LMC. Bad mistake. It was stiff and jerky and got so stiff during a 40 mile drive that it began to bend my pedal rod assembly. I had to put the old one back on. I went to GM and they no longer make the cable, so you have to find an old stock OEM cable on a shelf somewhere or find a good aftermarket one. I found an OE one online and it was soooo buttery smooth.
I vote to find an OE cable. If you plan on keeping the truck for a while, buy two, they are cheap enough.
12turnda
