Show off your non-square project cars.
xm20k
Girard, Ohio
My other Chevy project. 51 Sport Coupe Gasser
Steelbuddha
Firefighter
Central North Carolina
Jonathan
K20 (dump bed)
Yep it's got those seats. Leather, fake walnut, Bose sound, OnStar, tint, power everything including moonroof ...They pretty much through the kitchen sink at it. They went for like 30k right up next to the Blazer that was only 15k or something like that.
I had a '91 S-15 Jimmy 4-door that may have been my favorite vehicle. Found a pair of leather, powered Bravada seats in perfect condition on eBay, bolted them in, and rode in style and comfort. That little truck needed a bunch of new parts at 210K miles, and at the time I didn't have a shop so I let it go. Regret doing that. Nowadays I would put the thousands of dollars in parts and untold hours of labor into it and make it new again. Smart business decision? Of course not.
gilby959798
CLT NC
GMC K25 Camper Special
Those don't look obviously different from a traditional sealed beam, which I do like. A little bit pricey but not outrageous. I'd like to know what the actual current draw is - the main reason I switched as much as possible to LED was to take load off the fairly small alternator. I also want to reduce current in the harness (MG did not believe in using relays for anything), everything electrical is hot-switched right at the panel. I can't do much about the defog blower, horns or fuel pump - there is a 3rd party relay kit for the headlights which I may also do.
This is what is on the website. For what its worth, I have them in both the truck and Mustang using factory wiring and they work perfectly fine. https://www.auxito.com/products/brightest-h4-led-headlight-bulb-120w-24000lm-motorcycle-headlight
Normmus
Saskatchewan
Norm
Thought I'd posted but I guess I didn't. The Dodge was meant to be a work truck but I always seem to be working on it so it qualifies as a project.
The jeep is SBC swapped.
dragstews
GMC-IH
Belleview Florida US of A
Body 1954, frame 1975
R-100
406 ci SBC
To put it back how Chevrolet and God intended?
A bit to far gone to go back to a 80 El Camino or a 50 Studebaker Champion now ...
YakkoWarner
Central Texas
Wolf
R2500 Suburban
If anyone is still reading along on this (if not tell me to shut up):
This is what I had to work with at the beginning of the year with professionally zip-tied instrument mounts.....
By June I got to this point...sourcing lamp holders for the hi-beam indicator and alternator warning bulbs being effectively impossible.....the only option was to buy incorrect ones that were similar size and hack they apart to get the original bulb assemblies into then (which is what I did for the green turn signal indicators) and even then they would be the wrong colors.
As of last weekend - almost starting to look like a usable front panel now. I did a repurposing (without modifying or damaging the factory harness) of a redundant seat belt warning lamp to become the overdrive selected indicator in the center panel. It was part of the harness but requires seats with the pressure sensors - my seats are from an earlier year without any sensors. I just patched in a wire from the overdrive solenoid (using factory connectors) to that lamp. The custom solid brass lamp holders for the hi-beam, alternator warning and (now) overdrive selected indicator bulbs are actually old mobile home plumbing fittings that took a quick ride thru the lathe to turn them into a flush front flange. The bulb assemblies fit perfectly into the backside like they made for this (even though they weren't) and they are much more durable than the unobtainable factory plastic parts. I just need to get some colored plastic to make lenses for them and I might redo the turn signal indicators the same way just to keep it all consistant.
I made a blanking plate where the original (and I don't have it) AM radio was supposed to be, and put the OD indicator, a second 12V outlet, clock and voltage gauge there. These cars didn't come with a voltage gauge which was always to me a shortcoming. I couldn't find an affordable genuine Smiths UK gauge from a different model car, so I went with something that looked close (and was the correct size) from the local parts store. The clock is an actual factory clock from the 1976-1980 year cars, prior to 1976 no clock was provided.
At this point everything with the exception of the heater controls is functional (including all the backlights). The right hand switch in the center panel is for the map light above the clock, but I chose to use a factory headlight switch (same size) instead of the basic on/off switch. Now I can connect the map light to the first click connection, and then add some (also never provided in any year on these cars) footwell lights on the second click connection and have footwell lights without losing the original map light functionality (and again no modification to the hactory harness). The harness for the center section was already pretty chopped up by multiple previous owners but I've been using factory style bullet connectors for everything I changed which tie back into the undamaged main panel harness. The hazard lights wiring was just chopped out completely (I suspect someone 'harvested' the original 6 pin connector that is no available for purchase), so that wiring is not original style - but not visible either.
Thanks to the tips I got here, I have the low-profile battery terminal for the positive side all set up on a custom battery cable. The stock cable was too short because this is not the factory battery configuration, there would have been a 6-volt battery on each side of the driveshaft tunnel originally.
goldpack
Adirondacks, NY
Donnie
GMC C2500 Camper Spec.
350 with 350 3 speed
a bullet nose baker reminds me of this very very hard to get movie O.C. and Stiggs, as it has one (or 2) I seen it exactly 1x but the Baker turned Gila Monster with the rising body is very memorable. (it was shot right in Phoenix)
SquareDad
Julian,CA
My 55’ Pontiac wagon. Pretty basic driver/grocery getter. 350/th350. Everything done on it ive done myself on a budget. It’s come a long way. When I bought it, the floors were completely rusted out. Fixed that. Replaced all the wiring. Cleaned up the seats. spray painted the dash, new carpet up front, a shag rug I cut up for the back.
Still needs an exhaust. I also want to lower it a little.
I have another 350 on a stand in my shop I’m going to start throwing some money at and see what happens. But for now she’s good enough for the girls I roll with.
SquareDad
Julian,CA
Gotta love a horn ring! Front door panel off for the stereo upgrade?
No I’m getting ready to replace those as well. The front door panels were unfortunately all chewed up when I bought the car. My stereo right now is just a blue tooth speaker that sits on the seat next to me
Craig Nedrow
NADAR UNDER THE RADAR
Washington State
Craig
1973 (have two), 1985
K10, K20, C20
350, 454, 6.2 Detroit
Hey squaredeal, that is ultimate cool, that would be my fishin rig, love that car.
duncan_schawalder
