Shift linkage problems
Shibuya
canada
shibuya
I have a 1986 Chevy c10 350 engine with turbo 350 transmission. I have been doing a little work on the engine and decided to install some new stainless headers I bought, they are new but I bought them off the craigslist knowing I may have some issues with the install. They actually fit fantastic I think they are for a 90's chevy truck but the only problem I am having is they just slightly get in the way of my shift linkage going from the firewall to the transmission. I have been unable to find any aftermarket shift linkages that differ from stock to possible rectify this issue and was curious if anyone knows of any that I can buy before trying to modify my current shift linkage. Picture is of the wrong side but I am not going outside to get another picture of it, this is to just give an idea of what I am working with.
Shibuya
canada
shibuya
yeah the lokar cable shift if it will work is the kind of idea I was looking for. I went out and took a picture you can see the black shift linkage bar in the picture the vehicle is currently in park but if I shift into drive it will rub on the header.
Shibuya
canada
shibuya
Is Lokar the only company that makes something like that?
Moderator
Is it just the lever/arm that contacts the header? If so, you can bend it off to the side a fair amount and it will function as normal, after adjusting the rod.
Shibuya
canada
shibuya
It is just the arm that is rubbing, I figured the whole truck would just burst into flames if I tried doing anything the cost effective route. I appreciate the input Bucket I did not realize it should have an adjusting rod, I will see how far I can bend it out of the way before spending money on a new style of shift linkage.
Moderator
I bent mine probably 30° or so. I don't know if I had to adjust the rod, but I figured it wouldn't hurt. The upper end has a lock down bolt, just loosen it a bit and the rod can be adjusted. I like doing it with the trans and shifter in the Drive (or OD) position. Then just make sure it fully engages in Park.
Shibuya
canada
shibuya
cool I will give it a try thank you.
peats
Pennsylvania
john
k5 c10 k10 SSR doodlebug
406 360 6.2 5.3 171
it wouldn't take much to fabricate a new custom shift rod. not high tech.
Raider L
Shreveport, LA
William
Buy a different set of headers so the tubes will clear the linkage. I have the Lokar shift linkage on my truck but I'm running a set of Hookers to. And they are way clear of the shift linkage.
The P/N for the TH350
I'll take a couple of pics of it tomorrow on the truck so you can see how it fitted after the trans shop put it in. They did a good job and you'll be able to see about where to put the bend in the rod.
Raider L
Shreveport, LA
William
@Shibuya,
Here's the pics of my Lokar shift rod install.
How it's attached to the shift arm on the column.
You can kinda see it going down to the trans arm. The bend is not as crisp as I would have liked it, but it's how they did it. If I had a lift I'd take it off and rebend it. But it is what it is and it works so I'll probably leave it alone.
Attachment on the shift arm on the trans.. Sorry if it's not as nice photos but it was all I could do on my back under the truck. Hope people can get the idea of what it looks like. Just look at the kit and then look at what pics I shot and you might see how it's done.
Shibuya
canada
shibuya
Yeah that is not the same unit I was looking at when I looked up Lokar shift linkage I actually really like the unit I found instead I am going to order one this week. Buying a new set of headers seems a little excessive when I can easily solve this issue. I have decided to go with the Lokar ACA 1805. I appreciate all the help and pointing me in the direction of Lokar products even if we were not looking at the same item.
Raider L
Shreveport, LA
William
@Shibuya,
Yeah, that one works good if you've got enough room where the cable attaches to the column arm. I was even looking at changing over completely to a Lokar floor shift kit. It is the cleanest I've seen. You can get their back up/neutral safety switch they make that is real compact.
But the one you've picked will allow you to keep the column neutral safety switch/back up light switch on your column. Let's see some pics of it when you get it in!
deviatedsheep
North Carolina
brian
K30 M1028 Military
6.0 LQ4
Don't buy the Lokar yet. Try the Free Option and bend your rod. If you buy the lokar linkage, you most likely will have to bend it as well. When I put my 4L80e into my K30, everyone is using aftermarket shifters, so tried putting my TH400 shifter arm on my 4l80e, bend the rod a little bit and now I have long tube headers with a factory column shift linkage. But because my trans sits further back due to my LS engine mounts, I had to move my shifter bracket 2" back but you wont have those problem.
NateP350
