Scratchin my head!
Chris Jackson
Hello all,
Just picked an 86 c10 350/350.
I'm hooking up open ended plugs and wires under the hood (thermostat etc). When I connected the thermostat wire it tripped something, now when I engage the key switch to start I lose ALL power. I can disconnect the battery and let it set for a few and I regain power (lights, radio) but when I engage key switch to start the same thing happens.
Any ideas are appreciated,
Thanks, Chris
Howdy!
Sounds like it could be as simple as poor battery cable connections.
Chris Jackson
I would agree, but I replaced all that last week. Lol ‍♂️
dvdswan
Port Orchard, WA
Dave
Welcome to the site. If you disconnect the t-stat wire does it still do the same thing? If it cures your issue, you t-stat wire is shorted to ground somewhere.
1973c10
Don
Welcome
Chris Jackson
Good morning guys and thanks for the greetings!
It now does it either way. I'm thinking I may have a fusible link that isn't quite blown out and is letting just enough current run thru to power up but not crank.
Babs
Ottawa Valley
Chevrolet CUCV
:welcome:
WFO
Texas Panhandle
Welcome from up in the Panhandle.
Termite_Delight
Lanark Ontario Canada
K2500 K2500
350 L33
That's what happened to my '85, the Previous Owner replaced the alternator, starter, cables and battery. I installed a new terminal end and was good to go! ;)
johnalen76
