Rust removal tools
Anybody use something else besides a wire wheel or sand paper?
Sent from my iPod Touch 4th Gen.
Stroked
Beloit, Kansas
Jared
I've also used a couple different wheels that fit in a drill. They kinda look like a beefed up scotchbrite pad. I'll see if I can find a pic.
I like a sanding disc on a grinder. It makes quick work of it :)
Stroked
Beloit, Kansas
Jared
Worked like a charm on the surface rust on my '86. Takes it right off without scratching the metal like a sander or wire wheel does.
cool! :waytogo: The sanding discs I used with my grinders did a good job of not scratching the metal either as long as I didn't apply a lot of unnecessary pressure on the disc. That rust and paint removal process was a tedious process!! I can't imagine when people did it by hand (without the use of power tools) back in the day! That would have been BRUTAL! :lol:
Good stuff! :High 5:
I actually need to pull the drain off the tub at home and clean up some rust starting around the hole and repaint it, lol. :shitsweak:
But I figured kill two birds with one stone, and use it for that and working on the Burb cancer later... :roflbow:
:lol: For some of that cancer in the burb you'll also need a cut off wheel and just cut that crap out of there!
Stroked
Beloit, Kansas
Jared
Haha, that's what I was thinkin :grd:
Yep, 89S needs a Sawzall for rust removal.:superhack:
sawzall
mini air saw
electric grinder
air angle grinder
die grinder
cutoff wheel
air hammer w/ cutting bits
air nibblers
DA sander
tin snips
drill
wire wheels
wire brush
...I use it all
Oh, and don't forget the stuff you need to put it all back together. C-clamp vise grips, regular vise grips, body hammers, dollys, welder, etc.
thaifighter
Banned
chilliwack british columbia
brian
k20custom deluxe 16.5 rims
350 sm465/np208
The list "Bucket" made forgot one thing " NEEDLE SCALER" invaluable tool, I peened my frame down with one gets in all the tight areas where discs and wheels cant get.... sure you can get almost the same effect with the air hammer and a point bit but it will take allot longer and the needle scaler works on thinner guage material It will work if the tub is cast iron lol
Yeah, those needle scalers kick ass. I think somebody stole mine, I can't find it. :lazer:
Bigskygearhead
