Runs out of fuel…
BJedi76
Soldotna, Alaska
B.J.
GMC Sierra Classic 1500 4x4 SWB
305”
Ok
All distributors do not have the same rate of advance,or maximum amount of advance,all vacuum advances do not come in at the same vacuum nor do they all have the same amount of advance All carburetor vacuum ports are not the same. All compression ratios,flame travels etc. are not the same.So when you have a mystery carb. and a mystery distributor,you have to determine where timing needs to be,which I can walk you through after your other issue is solved. You do know GM had 100s of different dist. combinations.Right?
Dave M
Banned
Australia
Dave
That's fine, so long as the tank is still able to vent. IE , If the vent line is plugged from the tank, the cap needs to vent. Just trying to throw some different thoughts out there.
I’m also a little confused about the process of using a vacuum gauge as a fuel pressure gauge.
Air compresses, liquid does not.
obviously I am missing something in the interpretation.[/QUOTE
Looking there there's a harbor junk one. I'm getting tired of you doubting everything I say. I know what I'm doing and trying to help.And whatever professionals have been advising you,quit taking their advise.
Lookee there there's a harbor junk one. I'm getting tired of you doubting everything I say. I know what I'm doing and trying to help.And whatever professionals have been advising you,quit taking their advise.
I’m not trying to be sarcastic or be a smart ass, but I’m starting to feel like a dumb ass.
I feel like I’m missing something very obvious, and it’s my lack of communication that is preventing anyone from noticing what’s wrong.
So now I am over communicating, hoping that will help, but it seems to be just aggravating some people.
You are missing something obvious!!!!!,you've changed the fuel pump 37 times, there's your clue.Whats going on there,you didn't have that many bad pumps.I would want to know what's going on there, so I can decide if it's related to what's going on now.
BJedi76
Soldotna, Alaska
B.J.
305”
Ok
BJedi76
Soldotna, Alaska
B.J.
305”
Ok
AKguy
Alaska
Randy
K30 Crew Cab Silverado
Call Rob. (907) 740-0541
Take the steel line off at the carb use a piece of rubber line and clamps to clamp the gauge to the line. Crank for 20 seconds with a remote starter switch or a friend. Post your reading. 2nd Take a piece of hose, clamp it to the line put the hose into an empty clear bottle, friend or remote switch cran for 30 seconds you should get about 6oz of fuel.
BJedi76
Soldotna, Alaska
B.J.
305”
Ok
I'm done, good luck.
Rusty Nail
Cowboy of both Time and Space
Russell
350sbc
Aww man it was just starting to get good!
Hay 76. Have you ever heard that when a buyer picks up the pen to sign, that's when to stop selling?
Rick even came back and gave you another chance. He told you what to do and even how to do it.
AND THEN!
You replied THIS!
So the “obvious” problem is the (3) fuel pumps that have been installed?
and “obviously” I have two or more issues happening at once?
I still don’t know what any of those are, but I’ve managed to piss off a couple people.
I thought this site was to cure ignorance. If I knew what the hell I was talking about, I wouldn’t be asking for an education.
Dude.
Stop typing and go do it. Stfu already -stop selling- and go fix your truck like the man said.
You will not be able to reason with it, you must do the work necessary.
Sounds to me like you could use an ass whuppin...maybe it'll learn some sense into ya.
BJedi76
Soldotna, Alaska
B.J.
305”
Thank you…
I will try everything suggested.
jwtlake
