Running a 4" lift and 37s??
87scotty
Central il
Andrew
V20
5.7 for now
Military tires 36 12.5 16.5 with a 6 inch lift I for believe need to learn how to measure lift and tires we're on when I bought it!!
87scotty
Central il
Andrew
V20
5.7 for now
I also was looking at the 37s
Jonesta89
Southern IL/STL
V2500 Suburban
350ci
I picked 285/75r16s up for $400 for everything and they have 1000 miles on them. (4) GT Radial Adventuro MT and (4) second gen dodge wheels they are mounted on
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
You may want to consider running 1" EZ lifts or Easy Inch. ORD and DIY both sell them. An extra inch of clearance also the ability to move the front axle forward an inch will help. You will still need to trim metal. You could also install a 1" body lift. Try to never go over 1" in body lift, eventually it will start to wiggle around and then your doors will making contact with the cab and other dramas will abound.
87scotty
Central il
Andrew
V20
5.7 for now
7inch 4 suspension and a 3inch body
Jonesta89
Southern IL/STL
V2500 Suburban
350ci
I wont be buying 37s or a lift anytime soon because in the same day I received a $147 speeding ticket and the I need brakes on all four corners. So for now I will be running my "new" 285/75s
Chaz
USA
Chaz
V1500 Suburban
350 tbi/th400/np241c
Wow speeding ticket in the suburban,,,,I drive mine slow all the time dosent feel right driving fast hahaha,,,,,
Chaz
USA
Chaz
V1500 Suburban
35's on a 6 inch lift
Jonesta89
Southern IL/STL
V2500 Suburban
350ci
I was doing 35 in a school zone at 2pm so theres no way to protest it.
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
Curt
K-10
350/SM465/NP205
First pic is sitting on some worn 38" TSLs, probably close to 37" on 4" lift. If you want a street queen that can never go offroad it will fit. Next pic is 38.5 TSL SXs on 4" suspension + 3" body lift. Last is 6" suspension plus maybe an inch gained from one ton axles having bigger/taller spring mounts, 38" new TSLs front, 38.5 TSL SXs rear.
87scotty
Central il
Andrew
V20
5.7 for now
Looks good
Jonesta89
Southern IL/STL
V2500 Suburban
350ci
I like the look of the 4" sus with the 3" body. How does it do off-road if you know?
crazy4offroad
Curt
K-10
350/SM465/NP205
It had open diffs at both ends so not the greatest but the tire size was the biggest help.
Sent from wherever I am right now
Rom Doggy
ca
mark
V2500
This is just like mine. I have 4" lift and 35's. They are fine, stock fenders, but they rub the running bar on severe downhill turns. I imagine the 4" lift would be too small for the 37's
Chaz
USA
Chaz
V1500 Suburban
My 35's have hit the rear of the front fender on 6 inch lift. I don't think it will hit anymore because I have b52 front spring hangers on which moved the front axle forward about an inch. My stock factory spring hanger blew out with the old sprngs.
GRat
