Rotten Egg Smell From Exhaust
DuallyGuy
San Fernando Valley, California
GMC C15 1/2 Ton Stepside
5.7L 4BBL 350 V8
I tried to search for a similar thread but couldn't find one. Forgive me if there is one out there. I've been going through my truck pretty consistently for the past year. I'm aware I have a 454 TBI, but I still think that my fuel is being used up just a little bit faster than it should. I also have this rotten egg smell coming from my exhaust. So I'm guessing that maybe unused fuel is getting by? Any suggestions? Thanks in advance.
P.S. Can someone also recommend a good donut gasket at the exhaust manifold flange? The guy I took it to put these cheesy flimsy donuts on and twice they've blown. Thanks :)
87sierra
Pennsylvania
Sierra 2500
5.7L 350 TBI
rotten egg smell means there is to much un-burnt gas getting to the catalytic converter
Jims86
Patterson,Ca
K10 Suburban Silverado
5.7 TBI
Do a compression check, look at the plugs. Maybe got some high sulfer gas too...dunnonhow that would happen in Cali though.
Usually happens when you floor it.
87sierra
Pennsylvania
Sierra 2500
5.7L 350 TBI
it could be possible that the exhaust leak is causing a lean mixture in the exhaust system and the o2 sensor is trying to fix it by adding more fuel
DuallyGuy
5.7L 4BBL 350 V8
The smell's always been there. I bought the truck just over a year ago. Even when the exhaust was ok it still had that bad smell. I just assumed it was some bad gas or something. But it's never gone away.
DuallyGuy
5.7L 4BBL 350 V8
There's no smoke exiting the exhaust pipe or anything odd as far as the engines performance. What could be the likely cause?
87sierra
Pennsylvania
Sierra 2500
5.7L 350 TBI
another is to look at the spray pattern of the injectors they should be a fine cone spray also a cheap possible fix is to install a fuel pressure regulator which uses a heavier spring making the fuel pressure higher this is what I have been told and I did this to my truck but I don't seem much of a difference
Jims86
Patterson,Ca
5.7 TBI
Yup, and a good way to check thte pattern, is to hook up antiming light to the coil wire, and point the light at the injectors.
No No on the heavier regulator spring, either replace, or have the injectors sonically cleaned.
87sierra
Pennsylvania
Sierra 2500
5.7L 350 TBI
okay thanks for the info about not using the heavier spring and when I compared my old spring to the new one they looked identical so I think it was the same tension
chengny
  • Pages from X8736_1987_GMC_Light_Duty_Truck_Fuel_and_Emissions_Including_Driveability[1].jpg
DuallyGuy
5.7L 4BBL 350 V8
Thanks for that info and for the paperwork. According to that page, I have noticed that my truck idles high when it gets hot. Not too high but def higher than it should. I've searched high and low for a vac leak. Maybe I just don't know how to check. The fuel injectors seem to spray just fine. I just inspected them last weekend. I wish you guys were my neighbors. LOL Come over and check out my truck.
eastcoastmat
mathew
k10 Scottsdale
Ive always thought that a rotten egg smell was a plugged or over heated catalytic converter.
1986K5Wa
Washington
Walt
My exhaust smells like alcohol, after being drove a bit. Is it to lean?
Mavric16
