Rollbar padding only sold in offset? Huh? Any engineers, builders or metal fab people to chime in?
buddy350
El Paso,TX
Buddy
1973 k20
Suburban
Just finished a 8 point roll cage and have been looking for some roll bar padding to put in areas around the driver.
Last time I built a cage was about 17 years ago and I seem to remember we always just used round foam padding with 1 3/4 inch center diameter.
Now all that seems to be out there for roll bar padding is what is called "offset".
I went ahead and purchased some offset padding only because I could not find just normal round padding anywhere and sure enough when I installed some of it I noticed right away it had a tendency to twist so that the thin side would turn towards the driver and the thick padded side would turn away from the driver.
That's a serious danger if a driver is out on the track and the padding were to twist or turn in the event of a accident the driver would be exposed to the thin side of the padding
This would not happen if the padding was a equal diameter all of the way around.
For the life of me I cannot understand why offset roll bar padding is the standard these days, just makes no sense.
I understand that padding should be fire resistant and so on and that could all still be achieved with equal diameter roll bar padding.
Anyone have any input on this matter?
Just apply a strip of 1/4" double sided tape to the inside of the padding. Preferably at the center of the 'thick' part.
TubeTruck
East TN
Denis
Suburban K10
LQ9
More material towards the driver gives more protection. I wrap the center and ends in electrical tape to squeeze it onto the bar.
CRM
Pasco, Washington
Casey
K2500
350 CI
Lowes or Home Depot. Any hvac or plumbing supplier.
Scott91370
Burleson, Tx
Scott
Sierra1500
My guess is two fold on why it's this way.
1) Thick material for the occupants helmet to hit
2) The roll bar can be a tighter fit to the interior of the vehicle
I like the two sided tape suggestion or a zip tie on each end (not as athletically pleasing).
buddy350
El Paso,TX
Buddy
1973 k20
Suburban
Got some solid ideas
Thanks
I’ll keep an eye out for those pool noodles and or some misc Hvac stuff.
MikeD
