Ring and pinion?
NewSquare
Springfield, Ma
Joshua
454 FI
So got into a little debate with a coworker. If you have a rear end with a ring gear set, spider gears and everything are ******. As long as your pinion does not come out, will installing a new gear set, same ratio, mess up your backlash? Given the pinion is un-damaged etc etc. thanks for helping settle this.
jt1200r
Huntingtown,MD
Jeff
r10
4.3/th400/3.08
when you put it together and paint the teeth then you will know
johnmc
mass
john
k 10
305 tuneport injected
Are you just changing spider gears? if so no you dont need to pull the chuck.but if you are trying to change just the rung gear. you cant do that. ring and pinion are matched set.
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
K-10
350/SM465/NP205
If the ring gear is the same ratio, more specifically the same tooth count and tooth angle (as in same model # by a specific manufacturer) you can swap it in but you'll still have to set backlash, end play and tooth pattern since the pinion will be worn.
thatcanuckguy
sudbury, ontario, canada
colin
c10 stepside
agreed 100%
Jleopard77
