Replacing the fusible link
custodian
Catawba
William
C10,
5.3 LS, 5.3LS
I'm looking at replacing some of my fusible links with inline fuses. Most of what I'm looking at replacing are 10ga wires. How do I determine what size fuse to use?
Fuses are not a good replacement for fusible links. That's why factory they didn't use fuses. Fuse and fusible link fail rate happens at a different amperage and time. There is no answer to your question. You'll have to use a fuse with to high of rating for adequate protection or low enough to protect but deal with frequently blowing fuse that can't handle the temporary overload a fusible link will.
Smtty58
Mass.
Lyle
R3500 Crewcab
IIR, there are slow blow circuit breakers that duplicate fusible links. Study a wiring diagram for the amp loads.
nvrenuf
Mobile, Al.
Places like O’Reilly’s have replacement fusible link wire. They aren’t 1:1 replacement wire size so be careful to get the correct gauge.
  • Like
Reactions: WFO
NLD79K10
Netherlands
Lars
Like Ricko said: fusible links behave a lot different to a normal fuse. Their characteristics are nothing like fuses as they will tolerate a bit of temporary overcurrent before burning through but will burn out pretty rapidly on a real overcurrent and don't have any real inline fuse equivalent. Fuses will either trip all the time a bit of excess current draw happens or will allow for wiring to catch fire because they have too high a current tolerance.
Not sure about your truck, but like mine it probably uses 14 and 16ga fusible links, I keep a couple of rolls of those sizes in stock just in case. It takes a little bit of soldering, crimping an eyelet and putting on a bit of heat shrink to replace a burnt out fusible link, but it beats having to replace a burnt out wiring harness or worse.
beast6303
