Replacing K20 fuel tank
longbeach
Maine
Wayne
Hi, replacing fuel tank on my 86 K20 duel tanks. What a PIA. Removed all the shields. Switching valve is way up in there. Looks like I have to unbolt bed and slide it back a few inches so I can get my hand in to disconnect everything from sending unit. Thoughts? Advice? Tricks? Thanks
legopnuematic
Licensed Junk Dealer
MO
Spencer
Copied this from a previous reply on this topic:
Two brackets that mount to the frame, 4 bolts each, you will be working from the inside of the frame rail. Don’t forget to remove the ground wire that goes from the sending unit to the frame before you begin to drop the tank.
When you go to reinstall install new hoses on sender, leave them plenty long and mark them, snake them over the frame rail. No reason to fuss around with short hoses.
Chevy 88
Canada
f7t6
GMC
Whats wrong with the old tank? Rusted through?
Unbolt the tank with the brackets,reach up with pruning shears,cut your hoses,use new hose going on. These really aren't a big deal I drop as a whole assembly,tank ,sender ,brackets filler,the whole ball of wax. I go back up as whole assembly,new hoses already clamped on the tank and second set of clamps loose on the hoses. Push the tank up start one bracket bolt reach up start your new hoses on ,push the other end of the tank up.bolt it all down.
longbeach
Maine
Wayne
Ya rusted out. Both tanks are bad. I've been using only passenger side for about 4 years. Just wanted to replace that one right now . But this has been such a PIA I may do both now. Thanks for replies.
longbeach
Maine
Wayne
Rick , do you have duel tanks? That switch over valve is way in there. Doesn't leave a lot of room on tank side of valve.? Thanks
Yes I have dual tanks . ^^^^ @idahovette gave you good advice. The valve is in an awkward place,but even with the tank in place you can get to it and it's lines.
I deopped my tanks a few years ago to replace the sending units. It was a PiA, but with a nearly empty tank I could put a 2x8 under it and raise and lower it with a floor jack. Once you get it up enough it can’t shift left or right and fall off the jack because it’s kind of crammed in there between the frame and the body.
As already recommended, use extra long fuel hoses and connect them to the sending unit before you install, then trim to length. I also suggest using SAE J30R9 or J30R7 EFI rubber fuel hose because it holds up better to modern fuels. You may have to buy it from Amazon or other online suppliers to get a good price.
longbeach
Maine
Wayne
I bought two tanks and neither match the original. The original has the flanges bent down 90 deg. on both sides and the aft end. On one the flanges were straight out all the way around. On the ohter they were bent like 45 deg. on both sides. I went with the latter and i bent down the flanges more in way of the straps. But, wouldn't go. Had to take it out and hammer the after end down, it was hitting the leaf spring mount. I don't know if anyone makes one to match original??
its just a method to create a gas tank, that seam is where two halves are joined. just flatten it..
Craig Nedrow
NADAR UNDER THE RADAR
Washington State
1973 (have two), 1985
K10, K20, C20
350, 454, 6.2 Detroit
here is a pictorial r&r of my 87 tank with part# etc. Start @ post 65
ss454elco
Pennsylvania
Rod
I replaced both tanks on my 84 long bed. Moving the bed is an option and makes access much better. However, you can do it like others said. A 2x6 or 2x8 and a floor jack work well too. I found it easier to loosen the strap nuts as the strap stud sticks through the frame when tightened. Be aware the threads are probably rusty and the bolt part may snap off, as mine did. I ended up replacing tanks, brackets, pickups, etc. from LMC Trucks. The tanks literally snapped into the brackets. I liked their tank because they were powder coated instead of zinc plated. If you reuse your brackets, just start nuts on straps, install tank, then tighten strap nuts.
Broken85
Cumberland, NJ
A
The valve can be changed from the ground, it isn’t as bad as it looks. When you have the passenger side tank down it is even twice as easy to do. It is only two bolts. Cut the hoses to get it out and replace with new fuel line. It’s a 90 minute job, even with the passenger side tank still up there tops.
longbeach
Maine
Wayne
Craig, looks like you're doing a great job on your truck. I got the same part# dorman tank and mine was zinc plated not painted. Plus yours had the flanges bent down 90deg.. Mine came sticking straight out. had to hammer them down in the way of straps and at the after end. I ended up lowering the tank some and reaching between the frame and the tank and cutting the hoses. My truck had tubing going over the frame. I went back with longer hoses and spliced a piece of wire into the ground so it would reach from sitting on the jack under the truck. the positive wire was long enough anyway. Thanks to all for the help.
hauto85
