Mark80K15
- Apr 18, 2021
- Sicamous, BC
- Mark
- K15
Hi all, need some mechanical advice. I have a 1980 K15 350 manual trans. I have unbolted the starter and disconnected the wiring. I was hoping the front propeller shaft wouldn't be in the way to pull the starter out, but I can't seem to move the starter down past the shaft. I also have headers... don't know if there is room if factory exhaust manifolds are installed.
So do I need to drop the shaft? I expect the answer is yes, so I already removed the bolts holding the u-joint straps to the front differential yoke. I can move the shaft back a little to disengage the u-joint from the yoke, but I can't move it back far enough to actually drop the shaft. Should I be able to move it back further? Or do I need to unbolt from the transfer case as well? Thanks for any advice.
