Rebuilding quadrajet, stuck secondaries
dkraven
Portland, OR
c25 Sierra Grande
Some of you might have seen my other thread on my engine dieseling. Decided to just rebuild and clean the carb before tuning and I'm glad I did as whoever did it before did several things wrong. This is my first time doing this but been making notes and watching videos. Got the whole thing apart but the secondary throttle shaft isn't moving at all. Is this a novice thing I don't know about or should these not be stuck like this?
fast 99
Spokane, Washington
They should completely open with full throttle. Usually secondaries don't need service during a rebuild. Try penetrant on the shafts and slowly work them until free.
dkraven
Portland, OR
c25 Sierra Grande
Starting with the pb blaster, also wondering if they'll loosen up when I dip the bottom plate
edit: so far no luck with the pb blaster or light hammering on the end of the shaft, it's pretty damn stuck
dkraven
Portland, OR
c25 Sierra Grande
Butane torch finally freed the stuck shaft, now I can put it back together.
FenderBanger
