rear tailgate power window motor Blazer/suburban
ratchetmaster
UT
Tim
looking for source for a new power window motor in my 1991 GMC Jimmy full size.
Anyone know where to get one for a reasonable price?
Are suburbans and Jimmys the same motor?
Thanks. Tim
Chevy 88
Canada
f7t6
GMC
Generally speaking, electric motors are easily rebuildable. Its far easier, far faster, and far less expensive than sourcing a replacement. If its not working, then your brushes are prolly worn out. The replacements don't have to be identical, they just need to be similar. I was in a situation where my convertible top motor was not working and they wanted $550 for a replacement. I fixed it myself in about 25 minutes, using brushes from an old vacuum cleaner.
Replacing an electric motor because the brushes have failed is like replacing your car because the alternator burned out. For some that is reasonable, but for many it is not.
Moderator
Iirc, my local Ace Hardware sells a few different sizes of brushes.
Zelph
Nevada
Maybe he doesn’t have a motor. Could be doing a manual to power conversion.
gmbellew
Kansas city
glen
suburban 1500
'nother vote here for Nu-Relics. Put their kit in my doors and it's awesome
gmbellew
Kansas city
glen
suburban 1500
Next time I have a window failure of some sort, I plan to use them also. I might even just jump to the 4 windows plus the tailgate window on the burb. Might turn out to be $1500 well spent!
Did you use the factory harness and switches?
They supply a harness and switches that you just run power and ground to
59840Surfer
Montana
Joe
You can buy them bigger and sand/file them smaller - wear gloves and wear a dust mask!
59840Surfer
Montana
Joe
Not just a few times I considered going the other way - electric to manual.
One thing I do is use some long-set epoxy to lock the drive ends into the motor and the drive unit ... just don't get any INSIDE the drive!
It seems this is where the basic failure is --- if it pops out, that blue driveshaft (a Bowden cable, really) will be junk the first time.
gearonabudget
wasilla alaska
mike
subruban v2500
so does the rear window switch go in the door panel? i thought it was by the ash tray?
No, I just did the door window motor kit cuz I have a pickup. The blazer window kit will keep the switch in the OE spot on the dash
samelthecamel19
