Rear disc brakes on the cheap
flegss02
IL
Michael
Are you using the 78 to 88 metric brackets from speedway?
speedy
MS
Brandon
I'm really wanting to do this on my 82 c10. Has this been a successful install? If i missed it i appologize.
MossyOakSlvrado
Maryland
Eddie
So after reading all of this thread, I went browsing JEGS to price the brackets and some complete kits. I see a lot of people looking for answers to the issue of a parking brake. Well one of the kits says that the calipers it uses are rear units from a 1980-1985 Cadillac Seville with emergency brakes. I hope this helps out with someone's build.
The parking brakes are dragging on my truck, it set for a while before I purchased it. So I think once I tear it all apart I am going to just upgrade to rear discs. I will take plenty of photos, along with the best step by step I can give. I also, will hopefully be able to locate the bolt on brackets. Even though I have access to a welder and could weld them on, most don't have a welder or could be hesitant to weld to their axle tube.
Gallionone
NC
Trevor
L6
I know this is an old thread, but looking to do this on my 76 c10 12 bolt. Anybody have an exact parts list? Or at least the the caliper brackets that will bolt/ weld up? Thanks
77 K20
Montana
K20 5" lift
HT383 fuel injected
Lowsub 84
Virginia
Raymond
C10 suburban
5.7 fi
I had a 1979 cadi with rear dics. Some of these parts may work too. Calipers have e braking. I'm going to check. Will post if its a go! 79 Fleetwood
BigPoser
Bakersfield, CA
Brandon
Cheyenne Super 10
Any update on this subject? I want rear discs.
thompson22
Greenville, South Carolina
ANTHONY
rear disc conversion
I'm new to the site...hello everyone!! I own an 82 C10 and I definitely want to do this conversion. So do this I would need the Astro rotors, Astro calipers, and Astro caliper brackets correct? Has anyone done this yet?? Pics and step by step instructions please!!!
street5
Nevada
Stephen
Which bracket from Speedway?
Which bracket did you get from speedway?
Jarhead79
Mt Vernon il
Michael
Still wondering if the oem master cylinder and stock brake lines work or do you have to change to different rear brake lines
77 K20
Montana
K20 5" lift
HT383 fuel injected
Technically I think you can use the oem master cylinder. I've heard of other people doing it. I wanted to have both reservoirs the same size as oem master cylinders are from the factory with front/rear disc brakes. I swapped out mine to this:
http://www.amazon.com/ACDelco-18M91-Professional-Cylinder-Assembly/dp/B000C9JDUC?ie=UTF8&psc=1&redirect=true&ref_=oh_aui_detailpage_o05_s00
I used the stock hard brake lines. But since I was re-doing everything I replaced the old oem rubber lines to both front wheels and the 1 oem rubber line to the rear axle. After 38 years or so they needed it.
Jarhead79
Mt Vernon il
Michael
That master cylinder looks like what I already have on my truck, I'm almost ready to try this!
4WDKC
Southern Florida
Kacy
For those that need a parking brake couldnt you use the rear disc brakes backing plate and all from a 94-96 Impala SS? They are the 8.5 10 bolt and have 5x5 lug pattern.
sunking
