What is the advantage of Hydro boost brakes over hydraulic?
kkgp81
Kelley
My K30 has hydro brakes and I need to replace all of the hoses. Looking at it I have the stuff to make it a vacuum setup. What are the advantages to the Hydroboost setup short of if your power steering pump cashes out you lose brakes and power
ali_c20
Austria
Alexander
C20, K5
Smaller package.
Way more stopping power.
Hydroboost: up to 2700psi
Vacuum booster: up to 1400psi
I never had a power steering pump fail from one second to another. Always started long time before failure with making noises, leaks, puke fluids.
Keith Seymore
Motor City
Keith Seymore
R10
4.3L
Hydroboost is used on those applications that don't generate enough vacuum to run the booster (like diesels).
K
xm20k
Girard, Ohio
Big ca
K
Or big cams with tons of overlap.
Moderator
Stick with the hydroboost. It's way nicer in a large truck.
bigy8s
