eskimomann209
- Jan 9, 2019
- Modesto
- Marcus
- C10
Eeeessshhh pinion seals... not always as easy as google makes it seem. Getting the pinion preload correct is important.I should really clarify what I did with the pinion at 0 degrees.
The axle is out of the truck on my shop floor. I blocked up the axle to get the pinion to 0 degrees.
Then I put the inclinometer on the spring perches and measured their angle, which read 9 degrees.
I only did the above so I could see what the perches were set at. I then cut off the perches.
The pinion seal leaks anyhow, so I have to replace it! The axle will not go in until this is done first.
I mean, after all if it can't handle a burnout with crappy tires I probably shouldn't be driving it
