Mismatched e-brakes: 73 axle swap on my 87 K15
AZ Highlander
Prescott AZ
Frank
K15 (aka V1500)
350 (5.7L)
Not sure how many have done this, but when I went to install the 1987 e brake cables, there isn't the same attachment to the drum brake backing plates. I figure that I'll need to custom fab something for the 73 axle e brake cables to work with my 1987 e brake system. After looking at my sons' 1978 K25 and 1982 Suburban, I think I will need to have the cable that goes all the way around under the frame in a rectangle, but unsure of exactly how it will all work out. Anyone else have this experience?
legopnuematic
Licensed Junk Dealer
MO
Spencer
I would keep your stock cables and adapt the axle rather than the other way around.
In my opinion the later setup is a better and simpler design.
AZ Highlander
Prescott AZ
Frank
K15 (aka V1500)
350 (5.7L)
Thanks Spencer. Not sure how to adapt the drum brake backing plates. I can envision adapting the front ebrake cables to tie into the rear, but not the other way around. Would like to use the later setup, but not sure how.
legopnuematic
MO
Spencer
Your 73 axle has the cable that bolts to the backing plate right?
legopnuematic
MO
Spencer
See here and here
This was a different situation, 70s truck with 70s axles, but lift much taller than the stock cables would allow. The 80s cables are longer and allowed it to work. He made a small tab to bolt to the backing plate and accept the 80s cables.
duncan_schawalder
