Rear Axle Bearing Play Some or None?
gearheadmike
West Chazy Ny
Sierra K2500
Ok so should there be any play in the rear outter axle bearing or none?
I have a little bit doesn't seem to be a lot tho. There is no leaks from the seals.
chengny
REAR WHEEL BEARINGS ADJUSTMENT
Before checking wheel bearing adjustment, make sure brakes are fully released and do not drag. Check bearing play by grasping tire at top and pulling back and forth or by using a pry bar under tire. If bearings are properly adjusted, movement of brake drum in relation to brake flange plate will be barely noticeable and wheel will turn freely. If movement is excessive, adjust bearings as follows:
1.Raise vehicle until wheel is free to rotate, then remove axle shaft.
2.Disengage retainer tang and remove retainer from axle housing tube.
3.Torque adjusting nut to 50 lb ft while rotating hub assembly. Ensure bearing cones are seated and in contact with spindle shoulder.
4.Back off adjusting nut until just loose.
5.Insert key into adjusting nut slot, if equipped. Install snap ring to retain key in position.
6.Lower vehicle, then install axle shaft.
GreaseDog
Elkhart, IN
1977 K20
1980 K2500
That only works on a full floating axle, there is no adjustment for a semi floating rear axle. There should be a tiny bit of play, but too much could mean a worn differential cross shaft, or wear on the end of the axle shaft.
chengny
Yeah I know - I meant to post just the top paragraph. I got sidetracked and forgot to delete the adjustment procedure. Now it's too late - no editing allowed after 24 hours.
BESTCHOICE
