Really hot after shut off?
83kid
Massachusettes
Hi,
So irecently replaced the heater core in my truck, and just before that the intake manifold gasket as it was leaking coolant.
So, now no coolant leaks.
But, Whenever i stop and shut the truck off, the temp with go up to around 210-215
Temp is 160-190 driving around town, perfectly normal
Why would it do this?
Carb'ed Vortec 350
Maybe a tad low on coolant and when it's turned off the water settles and steam rises up the sending unit. Steam is hotter than boiling water. Just a thought.
MadOgre
NA
NA
NA
NA
NA
You should do a good flush and see if it persists?
Driver4r
Nebraska
Trevor
k10,c20
That's normal. When the engine is running the water pump is circulating the water throughout the block. And cooling it thrue the radiator. When you shut it off the cooling factor goes away and it's still water. So the heat will collect. Then when you start it back up you circulate and add the cooling factor.
Georgeb
Wisconsin
George
K10 Burb Z71
2X what Driver4r said
83kid
Massachusettes
Just the issue i have with this, is before i did anything thatd affect the coolant, it would only hit around 200 or so off, and i didnt fill the coolant while running it since i did the heater core, so its probably a tad low im thinking
350runner
tx
Ceasar
norm...
firebane
Calgary, AB
Curtis
Cooling system are a closed and pressurized system. When you change one component other areas can become weak or work properly.
When no swapped the radiator and thermostat in my truck the next thing I knew my heater core failed.
Once I change that I should be good but I have 2 heater hoses and a water pump which could give me grief.
MadOgre
NA
NA
NA
NA
NA
Canadian Tire has those heater hoses for cheap. They come in a package with 5ft of both sizes.
rich weyand
Bloomington Indiana
Rich
The core of the engine (pistons, bores) is hot when running, and that heat is conducting away through the water jacket, which is being circulated through the radiator. So in the steady state while running, the engine core is much hotter than the water jacket.
When you shut the engine off, that heat in the engine core conducts out to the water jacket as before, but there is no circulation now to take the heat away. There is also no new heat being generated in the core, so it averages out pretty quickly, but that is what you are seeing.
My electric fans hardly ever run. Mostly just when I am idling at a light on a hot day. But about 10 seconds after I stop the truck and turn the key off, the fans kick on for about ten seconds.
350runner
tx
Ceasar
This^^^
Driver4r
Nebraska
Trevor
k10,c20
Pretty much what I said
rich weyand
Bloomington Indiana
Rich
Understood. We are both describing the same reality, which we both understand. I just phrased it a little differently, in the way I think about it. I thought an additional explanation might help the OP because he indicated he couldn't understand why it would happen.
Driver4r
Nebraska
Trevor
k10,c20
True true
88SQDRW
