re-seal top half?
Franken Chevy
Charlevoix
Justin
have a sbc 350 out of a 1978, it is bored to a 355, with a couple goodies on it. after running it the there day i noticed a little coolant pool on top of the intake. is this normal? the truck itself isn't put together right but the motor is. any help?
thx
Boone
Al.
Maybe just a loose clamp on hose? Ive noticed mine does this from time to time. I tightened clamp. Vacuum gauge shows no intake leaks. Have a 79, 350, 4 bolt main bored .030 over.
Sent from my SCH-S720C using Tapatalk 2
Driver4r
Nebraska
Trevor
k10,c20
Mabey your tstat gasket it sweating? Or leaking
By any chance do you have a cooling system pressure tester? Pump it up a bit and look for leaks at hose, hose clamps, Tstat, intake runners, and any TVS (Temp Vacuum Switch) usually used for EGR or Vac advance timing restriction for NOX reduction.
Franken Chevy
Charlevoix
Justin
Ill half to look. I personally dont have one but I have access to one. Ill have to give that a try too
ceyman72
