Rate my sparkplugs
13matsc
Norway
Mats
C2500
Go ahead and rate them!
Tell me what you see and what you think?
3800 miles on them. A bit of residue from anti seize when the were installed in 2023.
squaredeal91
Cave junction Oregon
Greg bush
1991 SB
5.9 Cummins 12 valve
Half look pretty clean. The other half look dirty/oily or in the shadows?
13matsc
Norway
Mats
C2500
Yes I’m seeing some oil on at least 2, 4, 8 + 3 and 7.
Also did a compression test on all of them.
Sad Sack
Nebraska
Goober
C15
Running Autolites in a Chevy? Blasphemy!
(but some aftermarket engines are spec'd for them)
Half are soiled and the other half look normalish. What if anything changed recently?
Sad Sack
Nebraska
Goober
C15
Obviously your compression is more than stellar.
350 w/203
1, 5 and 7 look nice. 3, 2 and 4 look okay. I can't see 6 that well and 8 looks like . . .
When was the last time you blew the gunk out of it?
13matsc
Norway
Mats
C2500
Will be AC delco next time Probably some shorties if I can find some. Having some clearance issues after headers were installed.
Does it smoke for a second on startup sometimes/allot?
Yea, some white smoke is visible. I have thought I might be just condesation, but maybe not?
What you mean by «blew the gunk»?
goose her violently uphill on the onramp kinda thing With a full bed or trailer etc
Also, your spark plug tapered seat on the heads, one of them looks slightly dirty, worth checking out with a a flashlight and a degreaser rag or plumbing soldering wire brush in hand
13matsc
Norway
Mats
C2500
Thanks. No, this is a summer truck here in Northern Europe. Mostly nothing on the bed and just small trips in and around town. Some hauling now and then, maybe 5-6 times over the summer.
I’ll clean them up some. I applied copper anti seize on them when they were installed, but that works like glue for all kinds of debries I found out.
Jeremy89
