Radio in-line fuses keep blowing
KRBishop
Boston, MA
Kyle
C10 Silverado
84 C10... Installed a new radio and the yellow inline 1amp fuse keeps popping as soon as I turn the volume up. Not even really loud. Just as I turn it in the glass fuse blows. Any suggestions? Thanks
KRBishop
Boston, MA
Kyle
C10 Silverado
That is what it was from fac
1 amp fuse seems kind of low in rating ?
That is what it was from factory. Even has a label on the fuse holder. I was wondering if I could increase because of newer radio?
Dave M
Banned
Australia
Dave
So are we talking the factory fitted fuse at 1 amp and the new radio/stereo is now a higher wattage and output ? It will draw more power, especially as you dial up the output. Try a 2 or 3amp.
Scott91370
Burleson, Tx
Scott
Sierra1500
Yellow is usually used just to keep the preset stations and time on aftermarket units and should be a 12v constant power. Red should be your key on power source.
In saying this, there is no reason the volume should affect the fuse on the yellow wire unless both the red and yellow wires are connected at the same feed or possibly a bad ground.
mnsouth
Fairmont MN
Brad
GMC Sierra 1500
just so we are all clear on this the "yellow" is the yellow wire from the after market radio? As Scott suggested that is often the save memory of presets and clock power so should be connected to an always 12Volt wire verses the red wire from the aftermarket radio that would be connected to a switched with the key 12 volt wire.
Don't go to a larger fuse stay at 1 amp or things might stay quiet even with a good fuse. :(
mnsouth
Fairmont MN
Brad
GMC Sierra 1500
Oh and red wire from the aftermarket radio I would guess is 3-5 amp fuse ... check the manual that came with the radio or check it out on the internet.
mnsouth
Fairmont MN
Brad
GMC Sierra 1500
In re-reading your post if you are saying when you twist -lock the fuse holder together the fuse blows ? if so you may have already passed the point of no return and the radio has fried some guts. Longshot /hail Mary check to make sure you do not have a switched power out wire of the aftermarket radio used for power antennas or switching on booster audio amps that is touching ground.
KRBishop
Boston, MA
Kyle
C10 Silverado
UPDATE - Since the aftermarket radio was a higher wattage, all I needed to do was upgrade the in-line fuses within the red and yellow to match the 10amp fuse in the back of the new radio. From factory, they were only 1amp and 3amp fuses. Now that I did that, everything works great. Thanks for the help.
FenderBanger
