Radiator Fan
firebane
Calgary, AB
Curtis
I know the water pumps on the vortecs spin opposite but what about the other motors?
I want to replace my non clutch fan with a clutch fan. Can I just grab any fan off any SBC that isn't vortec with a clutch and bolt it on?
Is there any styles or types that are better than another?
CSFJ
Seems like the fan blades would be the wrong way if it came from a non vortec engine.
MadOgre
NA
NA
NA
NA
NA
The clutch from any pre vortec will work. I think I even used my 6.2 clutch on my 350 when I converted. Non vortec fan styles can be mixed and matched as well.
Carb'ed Vortec 350
I'm guessing you would need to make sure the fan sits in the right spot in the shroud for maximum air flow too. Or maybe all the setups are the same. I don't know, but I too am looking at adding a fan clutch.
firebane
Calgary, AB
Curtis
I know that fans can vary in size so that is definitely something to think about as well as the depth.
But I'm not to concerned I'd just rather not have the fan spinning all the time.. they are NOISY.
Carb'ed Vortec 350
Yes they are noisy that is exactly why I am wanting to do it too.
MadOgre
NA
NA
NA
NA
NA
You will be surprised at how much power that old solid fan robs from you! I have one of those in my tool drawers. I ran it cause I had 3 clutches fail all in a row. when I finally replaced it with a new clutch I was surprised how much power it was robbing. Very noticeable!
firebane
Calgary, AB
Curtis
Good to know! Will be heading to PnP this weekend to pickup a air cleaner from a TBI and a clutch/fan for the truck.
MadOgre
NA
NA
NA
NA
NA
Don't grab any with wet oily spots on them as that is the hydraulic fluid leaking out. Dry ones can also be toast. sometimes the dry ones have leaked out all there fluid already and have dryed up.
Im not really sure what kinda test you should use.
Maybe someone else could chime in with what kind of things to look for. I definitely think the cleaner they are the better chance of finding a good one
87ChevyR10
Kansas
NA
NA
NA
If a fan clutch has failed, will it still spin the fan, but not at an audible speed? I had an 85 fleetside and everytime I started the truck, the fan would be audible for a few seconds then quiet down. On my current 87, I never hear the fan, but it does spin. I haven't had any overheating issues either.
Just curious. Thanks.
EDIT: After doing a quick search, it appears my 87 has a non-thermal fan clutch. The 85 I had before had a thermal type.
firebane
Calgary, AB
Curtis
So there is a alot more to this whole fixed vs clutch fan that what people make it out to be.
I went to PnP today and grabbed a fan with a clutch and when I brought it home and looked at the fixed fan I have the fan pitch is completely different.
So I did some research and essentially if the water pump uses a serppentine belt it will spin opposite to that of a vbelt.
So now I have a clutch and fan that I might be able to make work buy maybe going back to the drawing board.
MadOgre
NA
NA
NA
NA
NA
Cant you just bolt your old fan to it ? OH your old fan is not from a clutch fan ahhhh
firebane
Calgary, AB
Curtis
Yup exactly. I may look into just flipping the actual fan around and see how it works.
MadOgre
NA
NA
NA
NA
NA
Nope it will still be blowing the same direction. You need to go back and find an old square type fan
firebane
Calgary, AB
Curtis
Yeah unfortunately no square fans to be had :(
wilson79
